Parental Controls Device
(02-29-2016, 11:03 AM)jl_678 Wrote: Hi,
I like your idea. The one thing that I wonder about is bandwidth. You will need two Ethernet connections for your solution. The onboard nic will be one of them. What are you doing for the second?
If you are using a USB - Ethernet adapter, do you think that it will be fast enough given that the Pine uses USB2.0?
Thank you.
Sent from my XT1254 using Tapatalk
yes i would put the usb to ethernet on the red side linked to the dsl / router with the gig network facing the green
Parental Controls Device - by jm952370 - 02-24-2016, 01:25 AM
RE: Parental Controls Device - by Tarjei85 - 02-24-2016, 01:41 AM
RE: Parental Controls Device - by jm952370 - 02-24-2016, 01:48 AM
RE: Parental Controls Device - by jl_678 - 02-24-2016, 10:41 AM
RE: Parental Controls Device - by alg_42 - 02-26-2016, 11:02 AM
RE: Parental Controls Device - by jl_678 - 02-29-2016, 11:03 AM
RE: Parental Controls Device - by alg_42 - 03-01-2016, 11:54 PM
RE: Parental Controls Device - by jm952370 - 03-03-2016, 04:52 AM
  video scoring device for competition skydiving strictdev 0 2,838 06-29-2019, 11:33 PM
Last Post: strictdev
