IR Receiver
(06-17-2016, 09:05 AM)bcommando Wrote: Hi! Can someone show me an image of the remote sensor installed? I see where I think it should be soldered from the image above but I am not 100% sure. Thanks for your help!
Hi, did you see http://wiki.pine64.org/images/7/7d/Pine6...nector.png ? No need to solder, there is a 3x1 header where you can stick the IR receiver, as for the pinout, it is describe in the schematic and/or in http://wiki.pine64.org/images/d/da/Pine64_Connector.JPG. I just mounted mine facing outwards and trying to see if I can get it working with Linux...
IR Receiver - by hrh1818 - 02-22-2016, 01:58 PM
RE: IR Receiver - by MichaelMeissner - 02-22-2016, 02:12 PM
RE: IR Receiver - by tllim - 02-22-2016, 10:51 PM
RE: IR Receiver - by hrh1818 - 02-25-2016, 01:00 PM
RE: IR Receiver - by tllim - 02-25-2016, 07:15 PM
RE: IR Receiver - by RogerioNeiva - 05-15-2016, 06:36 AM
RE: IR Receiver - by hazerty - 05-15-2016, 06:43 AM
RE: IR Receiver - by bcommando - 06-17-2016, 09:05 AM
RE: IR Receiver - by xalius - 06-17-2016, 09:29 AM
RE: IR Receiver - by bcommando - 06-17-2016, 09:40 AM
RE: IR Receiver - by RogerioNeiva - 06-17-2016, 12:10 PM
RE: IR Receiver - by tiagomr - 06-22-2016, 11:10 AM
RE: IR Receiver - by xalius - 06-17-2016, 12:09 PM
RE: IR Receiver - by xalius - 06-22-2016, 11:15 AM
  Can the Pine64 act as a bluetooth receiver? photojoe 7 10,051 11-04-2019, 02:26 AM
Last Post: Partymack711
