Click on desktop Icon blanks sceen
I closed your duplicate thread.
First , use this link to find the Tx , Rx , and ground pins for the serial console on the EXP bus.
You may use 115200,8,n,1
Use this link to find a good cable.
The serial console just works.  Make sure that your wires are crossed properly:  Tx --> Rx   ;   Rx --> Tx
Also, make sure the ground wire is connected. You may use any serial terminal emulator on another computer to monitor the serial console on your pine board.  ( minicom, screen , and others )  I prefer to use gnu+linux ( Mint ) but you may also use your mac, or even Windows.
Again, it would be easier to help you live on the irc.  Stop by and we can chat.
Edit: irc is not the irc section of the forum... irc stands for Internet Relay Chat. You may use a free client like weechat ( or others ) to access the irc @ the address listed below .
Edit: If you're using the cable I recommended above the green wire (Tx) goes to EXP pin(8 Rx), the white wire (Rx) goes to EXP pin(7 Tx) , and the ground wire (black) goes to EXP pin(9 Gnd).
RE: Click on desktop Icon blanks sceen - by MarkHaysHarris777 - 01-25-2017, 04:48 AM
  Setting up QT for compiling on my desktop vincer 0 2,077 09-19-2020, 03:31 PM
Last Post: vincer
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,217 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 26,725 04-05-2017, 01:45 PM
Last Post: speedro86
Exclamation recurring blank screen on A64+ with ubuntu image & any desktop gui faddah 5 6,434 06-15-2016, 10:55 AM
Last Post: jl_678
