Android 6.0 Tablet and TV (release candidate, maintained)
#99
Question
Hi @ayufan, thank you for all your hard work on this OS, I really appreciate it!
I am trying to set up a couple of these boards for family to watch Netflix with, and Android TV 6 is the one I think will be best for now. It seems to be working well, and I was hoping to ask you two questions?
1. I believe we have to use the Netflix Android app (not the Android TV app) and so I have installed this, however it is hard to navigate with the Pine IR remote, as not all areas of the screen on the Netflix app can be accessed. For example, I don't seem to be able to choose a specific episode of a show to watch. Does this mean I should use a keyboard or mouse with this app? Or is it possible that the Android TV version of the Netflix app will work on the Pine64 in future?
2. I have noticed that the onscreen keyboard (I believe it is called the 'leanback' keyboard?) is a bit wrong. I think it might be slightly too large? I have uploaded some pictures (links below), hopefully you can see that the highlight circle is not properly over the letters (it rests over the 'search' button OK) and the bottom row of keys is not fully shown. Is this a bug, or something with my setup? (I am currently using it on a PC monitor, resolution 1920x1080@60Hz, on the 2GB Pine64 with your Android TV 6.0.0 v1.0.2 build 21 version.)
Picture 1 - selected 'd' key with the IR remote
Picture 2 - selected 'space bar' with the IR remote
Picture 3 - selected the 'search' button with the IR remote
Picture 4 - selected the 'p' key with the IR remote
Thank you for any advice you can offer, and thank you again for enabling this functionality for our Pine boards! Smile
RE: Android 6.0 on Pine A64 - by neyron - 11-26-2016, 05:21 AM
RE: Android 6.0 on Pine A64 - by Luke - 11-26-2016, 05:52 AM
RE: Android 6.0 on Pine A64 - by trenton4k - 11-26-2016, 09:07 AM
RE: Android 6.0 on Pine A64 - by ayufan - 11-26-2016, 10:20 AM
RE: Android 6.0 on Pine A64 - by mhump711 - 11-26-2016, 12:41 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-27-2016, 04:51 AM
RE: Android 6.0 on Pine A64 - by wappi - 11-28-2016, 01:02 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-28-2016, 01:06 PM
RE: Android 6.0 Tablet and TV (release candidate, maintained) - by Crispin - 12-19-2016, 01:17 AM
Shocked Remote for Android? liodra 18 29,836 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,895 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,008 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,083 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,356 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,754 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,560 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,695 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,696 01-07-2019, 01:21 AM
