Touchpanel information about heat and connection length
(02-10-2016, 05:32 PM)Zoidiano0 Wrote: more than concern abut the TP u should think about the LCD it self cuz becomes white when the temp is really high
the operation temp of the LCD is -20C to 70C
that says on the Datasheet
https://drive.google.com/file/d/0B0cEs0l...Pbm44/view
and expendable only if u can get a longer cable on the part store (not the pine64 store)
Well, I was referring to the whole thing, meaning LCD and all. 70C is a fairly high. Just for comparison, I looked up the maximum operational range of an actual car touch screen radio and they say the temperature range should be kept between 14F and 140F, (-14C and 60C). If this can be used up to 70C, then I think it might be ok to use.
RE: Touchpanel information about heat and connection length - by MostHated - 02-11-2016, 08:29 AM
  Question about Touchpanel monmoonmooonmoooon 36 47,667 11-06-2016, 09:35 PM
  Information & installation of the LCD [GERMAN] JulianM 1 3,146 08-05-2016, 11:21 AM
