Alternative 7" LCD for Android
(11-14-2016, 04:52 AM)neyron Wrote: Hello,
There is any alternative LCD with touch panel that will be work with Android? Lcd from Pine64 store has terrible viewing angle... If lcd has hdmi with usb touch, it will be ok too.
Beware that USB touch controllers require a driver that might not be available in Android kernel and that HDMI only supports a few common display resolutions.
With ayufan's Android all you need is an electrically/mechanically compatible LCD using the same touch controller since then you only have to adjust display dimensions in .dts.
Alternative 7" LCD for Android - by neyron - 11-14-2016, 04:52 AM
RE: Alternative 7" LCD for Android - by Armbian User - 11-16-2016, 04:17 AM
  Humidity sensor and temperature under Android dhewko 0 2,765 03-11-2017, 10:18 AM
Last Post: dhewko
