micro SD speed
(02-09-2016, 02:09 PM)stephen fleming Wrote:
(02-09-2016, 12:12 PM)KryPtAlIvIaN Wrote: Not sure if this pertains to the conversation, but I was able to transfer a Dreamcast ISO from a Flash drive to the Pine through a USB Hub at 19-29MB/s.
Unfortunately no, the SD interface is not the same as the USB. I do not have my Pine 64 yet, so I can not do any testing myself. However, if you are running Linux here are the commands the people a Hard Kernel used to do the test on the Odroid C2:
   Write command
   dd if=/dev/zero of=test oflag=direct bs=8M count=64
   Read command
   dd if=test of=/dev/null iflag=direct bs=8M
Depending on how fast you micro SD card is, that can also effect the results.
I don't talk anymore , but you topic is this  price $40 Odroid C2 2G to compare $29 pine64 2G i saw is not fair.
if Odroid C2 the price is $29 , i think is fair to compare .
and pine64 have 1G , 2G choose , but Odroid C2 have not , and for me is basic user only 1G $19 enough
micro SD speed - by stephen fleming - 02-08-2016, 05:30 PM
RE: micro SD speed - by tllim - 02-09-2016, 01:17 AM
RE: micro SD speed - by stephen fleming - 02-09-2016, 03:44 AM
RE: micro SD speed - by KryPtAlIvIaN - 02-09-2016, 12:12 PM
RE: micro SD speed - by stephen fleming - 02-09-2016, 02:09 PM
RE: micro SD speed - by joe - 02-09-2016, 11:25 PM
RE: micro SD speed - by Danton - 03-12-2016, 08:31 AM
RE: micro SD speed - by Ghost - 03-12-2016, 08:32 AM
RE: micro SD speed - by Danton - 03-12-2016, 08:49 AM
RE: micro SD speed - by janjwerner - 03-14-2016, 12:28 PM
RE: micro SD speed - by tllim - 03-15-2016, 08:40 AM
RE: micro SD speed - by Tassadar - 03-31-2016, 04:06 AM
RE: micro SD speed - by Andrew2 - 03-31-2016, 05:46 AM
  High speed I/O richw42 3 6,522 01-15-2017, 04:08 PM
Last Post: richw42
