Battery Takes Forever To Charge
(10-15-2016, 05:06 PM)MarkHaysHarris777 Wrote:
(10-15-2016, 03:42 PM)Bluphire Wrote: My pine just about died last night so I turned it off and plugged it in to charge over night. We are now at about 18 hours since plugging in the pine-provided charger and the battery indicator is at about a third of the way full. Settings>Battery shows 34%. I'm running Android 5.1.1 Image (LCD Panel Video Output) Release 20160603 64BG rooted on Samsung Evo 64gb SD card.
Any ideas why charging is painfully slow?
Matt
Do you have a two wire, or three wire setup ?
... if a two-wire setup, do you have a 10K ohm resistor running from the center position of the board connector to ground ?
If you have a three wire setup, try reseating the connector. Try charging the unit with the Android shutdown. You may have a bad battery (which one do you have?)  You may have a bad PMIC on the main board (I don't think so, but maybe).
3 wire. I will try reseating the connection and reply with results. Thanks for the reply.
Matt
Battery Takes Forever To Charge - by Bluphire - 10-15-2016, 03:42 PM
RE: Battery Takes Forever To Charge - by Bluphire - 10-15-2016, 05:28 PM
RE: Battery Takes Forever To Charge - by Bluphire - 10-15-2016, 08:25 PM
RE: Battery Takes Forever To Charge - by JimKirk - 01-02-2017, 08:11 PM
RE: Battery Takes Forever To Charge - by tllim - 01-04-2017, 06:43 PM
  Battery for Pine64 steve8939 7 13,026 08-27-2017, 06:23 AM
Last Post: lijinraj
