NAS setup
(10-12-2016, 12:22 PM)Luke Wrote: You can just set up smb or use the OMV img that was once posted here and just set up everything you want / need from the browser.
If all you want is connect an external HDD (remember to use a powered hub!) and not fiddle with anything, then just download any base img, ssh into the pine64, and follow these instructions (they are for the pi but will work just the same on the pine): http://raspberrywebserver.com/serveradmi...twork.html
Just adjust the parameters for ubuntu or debian !  .... so if you go with debian: smbpasswd -a debian
and in path: path=/home/debian
Thanks Luke, I will give that a try.
(10-12-2016, 01:10 PM)tampadave Wrote: The pine64 2G/1G versions have the compute power and network throughput to operate as an NAS (network attached storage) device.  But they do not have either sata or esata, so your best attachment to drives are through an usb 2.0 (480Mbit tops) interface, which is shared among all devices (single collision domain).
And that part of it stinks.  No getting around it.  That makes if at best, a low performing NAS.  It will work, and if its performance is adequate, then do build it.  Just don't look for sustained performance greater than that 480Mbit usb 2.0 choke point.
David
Thanks for your input, but I have to try it.
NAS setup - by clarkss12 - 10-12-2016, 09:13 AM
RE: NAS setup - by Luke - 10-12-2016, 12:22 PM
RE: NAS setup - by clarkss12 - 10-12-2016, 02:06 PM
RE: NAS setup - by Luke - 10-13-2016, 07:08 AM
RE: NAS setup - by tampadave - 10-12-2016, 01:10 PM
RE: NAS setup - by clarkss12 - 10-13-2016, 10:06 AM
RE: NAS setup - by Bob123456789 - 10-19-2016, 03:03 PM
RE: NAS setup - by Luke - 10-20-2016, 04:51 AM
  need help, looking to setup NAS server over OpenWRT subbu 0 2,634 05-26-2018, 07:48 AM
Last Post: subbu
