Using Bluetooth for Sending serial data
I'm using Ubuntu long sleep OS on pine64+, I'm trying to send serial data from the pine 64+ to the Arduino UNO over bluetooth.
For that i installed Bluez package and when i check for the bluetooth device using "Hcitool dev", its empty.
But i checked the status of bluetooth using "etc/init.d/bluetooth status", the result is,
Quote:● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2016-09-11 05:43:23 UTC; 3h 18min ago
     Docs: man:bluetoothd(8)
 Main PID: 7439 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─7439 /usr/lib/bluetooth/bluetoothd
When i add a USB bluetooth adapter to pine 64+, it gets detected and works fine.
I tried this using the procedure given in the following link:
           http://blog.whatgeek.com.pt/2015/09/blue...d-arduino/
Using Bluetooth for Sending serial data - by Arjun - 09-11-2016, 03:04 AM
  Wifi / Bluetooth Board Update S265 2 4,162 07-30-2020, 04:53 PM
Last Post: S265
Information Howto: Getting Bluetooth (serial console) working on Debian pfeerick 14 31,717 08-19-2019, 04:33 AM
Last Post: Roverius
  RTL8723bs Bluetooth xalius 21 33,279 03-22-2017, 04:53 PM
Last Post: JulianM
  WIFI & Bluetooth? 7777777 14 28,169 12-24-2016, 05:01 AM
Last Post: Toriless
  How can you get the WIFI/Bluetooth module separate? GoZone 8 11,340 07-06-2016, 05:23 PM
Last Post: JasperBrown
  WiFi/BT module, no bluetooth riviera89 5 7,234 06-24-2016, 04:32 PM
Last Post: srinivas.s34@gmail.com
  Board doesn't boot when wifi/Bluetooth connected with Lcd screen Krinilssen 4 6,823 06-16-2016, 07:22 AM
Last Post: Krinilssen
  WIFI/Bluetooth Chipset monmoonmooonmoooon 2 5,126 01-20-2016, 06:02 AM
Last Post: monmoonmooonmoooon
