Can I use HDMI + USB touch screen?
(08-29-2016, 07:24 PM)pfeerick Wrote:
(08-29-2016, 02:10 PM)MarkHaysHarris777 Wrote: The only LCD touch screen that works with the PineA64 is the one provided through the Pine store and specifically designed to be used with the Android LCD image and the Pine board.
At this point in time no other LCD touch displays work with the Pine board.
Huh? This LCD plugs in via the HDMI, and uses the USB for the touch interface. Surely the LCD at least would still work with the HDMI output Andoid image? , But the capacitive touch would be debatable depending on exactly how it is implemented? It was designed for the Raspberry Pi, so on linux it can't be hard to get it to work (if it doesn't work out of the box).
If someone finds an LCD that plugs into the hdmi and has a usb touch interface that works on Android, I will personally pin the reference to it sticky on this forum and start pointing people to it !
Big Grin
Can I use HDMI + USB touch screen? - by Voyager - 08-29-2016, 12:56 PM
RE: Can I use HDMI + USB touch screen? - by MarkHaysHarris777 - 08-29-2016, 10:41 PM
RE: Can I use HDMI + USB touch screen? - by mus1c - 08-31-2016, 08:20 AM
RE: Can I use HDMI + USB touch screen? - by mus1c - 08-31-2016, 04:53 PM
  Pine's HDMI-VGA adapter SkimMilk 4 7,399 01-18-2017, 05:40 PM
Last Post: wpersin
  Can I plug in the Pine with touchscreen to My tv via HDMI? acv2boriqua 3 6,151 10-15-2016, 08:27 PM
Last Post: Bluphire
  LCD TOUCH SCREEN PANEL SuperArmySoldiers 2 4,448 07-23-2016, 02:36 PM
Last Post: SuperArmySoldiers
  HDMI --> VGA Adapter Compatibility marco97pa 18 21,326 05-08-2016, 04:05 AM
Last Post: frewind
