more RAM
(12-11-2015, 05:19 AM)tkaiser Wrote:
(12-11-2015, 04:52 AM)tllim Wrote:
(12-11-2015, 04:27 AM)hape Wrote: is it possible to discuss to get more memory such as 4GB (or more)
Hi Hape, we will explore into 4GB possibility. One question, why need such high capacity? for what type of application?
According to the A64 User Manual:
Quote:2.1.3.2. SDRAM
  •   Compatible with JEDEC standard DDR2 /DDR3 /DDR3L/LPDDR2/LPDDR3 SDRAM
  •   Support clock frequency up to 667MHz(DDR3-1333)
  •   Up to 3GB address space
  •   Support 2 chip select
  •   16 address signal lines and 3 bank signal lines
  •   32-bits data width
  •   Support Memory Dynamic Frequency Scale(MDFS)
Question answered  Tongue
BTW: Which type of DRAM are you going to use and which clockspeeds you found to be reliable?
Current board using Samsung K4B4G1646D-BCK0, 800MHz, and here is the datasheet link: http://www.samsung.com/semiconductor/glo...Rev102.pdf. Please note that from time to time, we may change DRAM vendor pending on market availability.
more RAM - by hape - 12-11-2015, 04:27 AM
RE: more RAM - by tllim - 12-11-2015, 04:52 AM
RE: more RAM - by tkaiser - 12-11-2015, 05:19 AM
RE: more RAM - by tllim - 12-11-2015, 06:35 AM
RE: more RAM - by hape - 12-11-2015, 06:53 AM
RE: more RAM - by tllim - 12-11-2015, 07:02 AM
RE: more RAM - by tkaiser - 12-11-2015, 07:44 AM
RE: more RAM - by versetti - 12-11-2015, 07:01 AM
RE: more RAM - by ryfong704 - 07-07-2016, 10:45 AM
