System LED mounting option using header pins and remote LED for use in the ABS case
The pic above shows the modification to the PineA64 board , by adding just the male header pins to the board where the system LED is marked out.  You'll notice how I have removed the pins from the header spacer and soldered them directly into the pcb , at the right height of course. The female-male jumper wires have been soldered to the system LED ( I used a 5mm low power 'bright' LED here ) and they may be plugged into the male header pins easily without difficulty.
In the pic above I have connected the system LED via jumper cables to my male header pins in preparation for mounting this board in my Radio Shack enclosure.
System LED mounting option using header pins and remote LED for use in the ABS case - by MarkHaysHarris777 - 08-28-2016, 01:25 AM
  Testing the GPIO pins shockr 7 9,488 08-10-2016, 05:30 PM
Last Post: MarkHaysHarris777
  Exp Header UART for TTL is True Serial Console (very nice) MarkHaysHarris777 12 17,092 08-01-2016, 10:37 AM
  Mapping Euler bus DC in and 5v DC out pins g_t_j 8 10,545 07-02-2016, 09:30 PM
  UART2 on PI header (pin 8 and 10) martinayotte 8 13,204 04-15-2016, 02:47 PM
Last Post: tkaiser
