Can't get power button to work
(08-28-2016, 05:13 AM)DonFL Wrote:
(08-27-2016, 10:11 PM)MarkHaysHarris777 Wrote: Edit:  Also, and this is important, on debian ( on mate desktop ) go into the Power Management Preferences and change the General Actions for the power and reset buttons !
System --> Preferences --> Power Management Preferences
Then click the General tab, and then set the power button to "Ask Me", and set the suspend button to "Do Nothing".
(hope that helps)
So should this config change make the reset button inoperable with Debian (I'm running Debian-Mate)?
Thats how I interpret it, suspend=reset...but even with "do nothing" as the suspend choice, the reset button still puts me in the unrecoverable sleep mode with a long or short press.
hi Don, no.
... reset is NOT suspend. The short-press of the power button is the suspend.  I turn that 'OFF' in my debian, because it suspends forever and won't wake up.  Apparently (says pfeerick) the new Android image does wake up.
reset is JUST a hard reset of the PMIC and it does just that... and its hard on the system because it doesn't care what is going on, it just drops the power and resets !
So, the config I noted above, to re-iterate, the short-press does nothing, the long-press pulls up the power down dialogue, and the really long press forces power off.
Can't get power button to work - by AidenH - 08-27-2016, 08:46 PM
RE: Can't get power button to work - by pfeerick - 08-27-2016, 09:11 PM
RE: Can't get power button to work - by pfeerick - 08-27-2016, 10:58 PM
RE: Can't get power button to work - by pfeerick - 08-28-2016, 01:08 AM
RE: Can't get power button to work - by AidenH - 08-27-2016, 11:38 PM
RE: Can't get power button to work - by AidenH - 08-28-2016, 02:45 AM
RE: Can't get power button to work - by pfeerick - 08-28-2016, 04:07 AM
RE: Can't get power button to work - by AidenH - 08-28-2016, 04:49 AM
RE: Can't get power button to work - by AidenH - 08-28-2016, 05:10 AM
RE: Can't get power button to work - by DonFL - 08-28-2016, 05:13 AM
RE: Can't get power button to work - by MarkHaysHarris777 - 08-28-2016, 05:18 AM
RE: Can't get power button to work - by DonFL - 08-28-2016, 07:19 AM
Question +LTS/SOPINE USB voltage on power off using LiPo battery GregH 0 2,496 05-06-2020, 11:23 PM
Last Post: GregH
  Battery case and power question Twistedx 2 5,465 12-24-2018, 08:04 PM
Last Post: Twistedx
  Power Cord & SD Card Maximum 1 3,017 01-09-2017, 04:41 PM
Last Post: Ghost
  Board will not boot/does not work major7 2 4,247 09-03-2016, 02:53 AM
Last Post: major7
  Wires as power button Nittola 5 7,457 08-19-2016, 03:35 PM
Last Post: MarkHaysHarris777
  Push button on/off switch Wolfenstein 6 9,145 08-01-2016, 11:05 AM
  Day lost in getting it work ptiwari 4 6,157 07-24-2016, 01:17 PM
Last Post: ptiwari
  Power Jumper rahlquist 12 17,094 04-03-2016, 09:29 AM
Last Post: SkimMilk
