Perfect ABS Plastic Server Enclosure from Radio Shack
This is the rear view (obviously) of the fully cased enclosure. I have very deliberately designed this box with the recessed ports in mind.  The purpose of the enclosure is to protect the board, yes, but mostly to make the board easily portable with everything in one tight box that can be tossed into a suit case for on-the-go. The enclosure is still a work in process; for instance, I am still waiting on my 5v barrel connectors for the power supply whether mains (as now) or whether solar array|SLA batts. Also I will be cutting a slot for the SD card, and a small opening in the top for the cp2102 serial console adapter !
The front view of the enclosure is designed to be simple and functional. The power and reset switches ( external ) will be added later-- once I get them !  The LED in the front panel is the system LED brought forward with jumpers. I am using the system LED as a boot-up indicator and normal operating system runtime indicator. This LED is activated rapid flash at the point of rc.local in the boot sequence;  and there after drops into a slow flash to indicate normal operating system runtime and temps-- its pace picks up if the fan motor speed control bumps to 100% duty cycle ON.
This is the ubuntu mate pineA64 board(B) booted and running normally;   Big Grin
... as well as some of the other junk in my lab.   Blush
RE: Perfect ABS Plastic Server Enclosure from Radio Shack - by MarkHaysHarris777 - 08-31-2016, 04:56 AM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 20,011 10-12-2018, 03:08 PM
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,501 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,562 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,735 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,048 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 25,070 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 20,075 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,093 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,643 10-13-2016, 08:47 AM
Last Post: Bluphire
Rainbow DMG/Classic Gameboy Enclosure!? n_n' Gearsoul 54 66,014 09-16-2016, 12:21 PM
Last Post: Ghost
