Perfect ABS Plastic Server Enclosure from Radio Shack
Lightbulb
ABS Plastic Server Enclosure 15.24cmX10.16cmX5.08cm from Radio Shack
This classic Radio Shack ABS Plastic enclosure ( 6x4x2 inches ) is ideal for the pineA64 board, particularly for server applications. These boxes are being marketed by Radio Shack and others like EBay and Amazon. The enclosure is readily modifiable , but is the classic rugged Radio Shack quality ABS box hobbyists and amateurs have come to expect for years.
The box has the classic interchangeable plastic or aluminum base plate fastened by four rugged corner screws. The cabinet is ideally suited (size and shape) for the PineA64 board; with room left for mounting power supply filters, batteries and GPIO cabling, or even a fan.
If you need a ground plane , the aluminum bottom plate (or top plate!) is perfect; else if you need a non Gaussian enclosure the interchangeable ABS plastic bottom plate is also perfect. While I do plan to place my desk Pine board on display in one of Dustin's classy cases, my headless server boards need to be protected too... and this little box is a perfect enclosure.
Perfect ABS Plastic Server Enclosure from Radio Shack - by MarkHaysHarris777 - 08-26-2016, 01:40 PM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,885 10-12-2018, 03:08 PM
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,462 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,518 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,700 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 12,966 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,917 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,964 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 18,992 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,609 10-13-2016, 08:47 AM
Last Post: Bluphire
Rainbow DMG/Classic Gameboy Enclosure!? n_n' Gearsoul 54 65,633 09-16-2016, 12:21 PM
Last Post: Ghost
