08-20-2016, 12:21 PM
(This post was last modified: 08-20-2016, 12:21 PM by Punkyclown.)
(08-17-2016, 03:19 PM)MarkHaysHarris777 Wrote: Mine works fine, on my Android Play Desk; however, I am using an experimental Android image which I received from TL Lim, for testing purposes-- will be made available later.
Try this: go into settings, and select display, then select 'hdmi output mode' to set the hdmi standard out.
I have two choices 1080p and 720p; I suspect that Punkyclown's is set to 1080p... setting it to 720p should give him the resolution he is used to.
Also, my fonts do change size.... I have the option to set small, normal, large, and huge... and they do just that !
Hi All, just wanted to update by saying that I was able to change the size of my screen by going in and editing the Bild.Prop
file in ES file manager. Path Device/system/. I changed the line "ro.sf.lcd_density=160" to "240". Now my screen is
readable and usable. This is running Android 5.1.4, I believe. Saw that on a uTube video comparing Remix Mini to Remix
running on Pine64.
Cheers, Brad Hansen
(08-17-2016, 12:39 PM)MarkHaysHarris777 Wrote: Its now taking advantage of the full resolution supported by your monitor (TV). Have you tried adjusting your TV video settings?
I run all my hookups, AppleTV and Fire Stick and Pine64 through my stereo system thru HDMI. Before it was the right
size and right display. Easy to read and watch, why should I have to goof around with my TV when the other displays
are correct? I thought Android was supposed to be so flexible with icon size and all aspects of display?
