Lithion 3.7 volt PineA64 battery Model 9070120P
(09-08-2016, 02:17 PM)MarkHaysHarris777 Wrote:
(09-08-2016, 01:49 PM)alaskanson Wrote:
(08-02-2016, 04:32 PM)MarkHaysHarris777 Wrote: With this setup (lennyraposo debian mate), the 2G PineA64 and motor speed controlled fan, usb receiver, LED GPIO lab, gps module (in the foreground) using as a full desktop PC mid to heavy loading,  I am getting six (6) hours of continuous use from the Pine64 battery model 9070120p  8000 mah lithion.
This is fairly consistent between my LCD cb&dt Play Box running Android.
Nice!  That is a decent stretch.  Is it possible for this battery to power the multiport I2C as well?  I've not found info online to help on this issue.
I have the 2Gb board and this very battery but using it turns off the POT.
-a
when running on batt, you MUST move the 5v|batt jumper to BATT.  The jumper is next to the pine cone logo near the SD card slot.   While running on batt, the 5v needs to come from the on-board batt regulator and WILL NOT unless you move the jumper to BATT.
Just got the lithium battery in the mail today. I understand how to install it and the jumper config. My question is; does the power supply recharge the battery when it's running the board? Also since this is a brand new battery should I do the usual charge for XX hours prior to running from the battery?
Thanks,
Mike
RE: Lithion 3.7 volt PineA64 battery Model 9070120P - by mcrognale - 10-27-2016, 03:07 PM
Lightbulb How many mA are the max for PineA64+? razgriz 0 2,272 04-21-2020, 04:13 AM
Last Post: razgriz
  PineA64 battery in Germany (specifications or alternatives) burningkrome 0 3,151 12-02-2018, 04:10 AM
Last Post: burningkrome
  Battery Backup for media center. Zone 4 8,409 09-13-2016, 09:08 AM
Last Post: MarkHaysHarris777
  RTC Backup Battery Holder CR-2032 Issues steveslim 11 26,045 09-08-2016, 07:02 AM
  Battery Power clackamas 3 7,349 06-13-2016, 02:18 PM
Last Post: clackamas
