SOQuartz Model A baseboard Real-Time Clock
There appears to be some kind of real-time clock on the SOQuartz Model A Baseboard, maybe even two, but I can't seem to get them to work. I bodged together a CR2032 holder and a JST-PH 2mm header which fits the connector on the board that is labelled "RTC". Verified with a multimeter that the battery has 3V across the terminals so it seems like it's plugged in properly, but I'm still getting "rtc rtc0: Power loss detected, invalid time, rtc-pcf85063 1-0051: hctosys unable to read the hardware clock" in dmesg. There seems to also be a /dev/rtc1 (rk808-rtc) that seems responsive to hwclock but on every reboot it reverts to August 5, 2017 09:00 UTC for some reason.
Anyone know the correct way to provide power to the RTC?
SOQuartz Model A baseboard Real-Time Clock - by stormwyrm - 11-17-2023, 03:52 AM
  Is the USB 3.0 port still an issue for Q64 model A? andreas1107 3 1,519 12-11-2023, 09:27 AM
Last Post: diederik
  SOQuartz with Waveshare CM4 fan heatsink stormwyrm 1 438 11-18-2023, 01:35 PM
Last Post: stormwyrm
  SOQuartz BLADE 3D server rack screws agriffith2134 1 624 08-14-2023, 02:23 PM
Last Post: agriffith2134
  Quartz64 Model A fan TeutonicTovarish 1 1,090 05-20-2023, 04:45 AM
Last Post: diederik
  Survey for Model B Owners: Stereo Audio HAT CounterPillow 1 1,250 03-01-2023, 05:48 AM
Last Post: manning
  Soquartz-cm4io emmc with usb host louisvinc 6 2,037 02-14-2023, 09:50 PM
Last Post: louisvinc
  SD card slot in Quartz64 model B psic4t 1 1,013 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,278 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 1,692 10-05-2022, 02:01 PM
Last Post: pitchbent
  DeskPi Super6C CM4 board with the SOQuartz adamfowleruk 5 4,159 08-09-2022, 03:22 PM
Last Post: tizilogic
