mounting root filesystem via NFS on pine64+ issue
I'm going to guess timeout (network latency) are you using udp, or tcp?, or auth issues, or driver issues. You should be able to boot from the network (technically). is the server on the same lan ? NFS does not work well on the wan, unless you're using tcp.
This is just too new. You are the first person I know who has tried this with the PineA64. I will follow this thread with great interest.
marcus
RE: mounting root filesystem via NFS on pine64+ issue - by MarkHaysHarris777 - 07-28-2016, 12:52 PM
  Pine64 Suddenly Turnoff with Lcd mix359 4 10,325 07-08-2021, 08:50 AM
Last Post: e-minguez
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 3,145 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 3,228 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Does Pine64+ have an internal hardware watchdog ? rahlquist 8 15,344 04-26-2018, 06:27 PM
Last Post: pfeerick
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 6,253 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  I dropped my Pine64 DukeJustice 17 20,599 11-07-2016, 07:23 PM
Last Post: DukeJustice
  pine64+ cad files danlcarr 1 3,705 08-31-2016, 08:26 AM
Last Post: martinayotte
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 4,011 07-30-2016, 05:47 PM
  Cannot get PINE64 boards to boot andymelton 13 17,311 07-06-2016, 09:20 AM
Last Post: montero65
  Pine64 2G never up w/ strange Chinese words + w/o S/N tankie64 1 3,578 05-13-2016, 04:36 PM
