More heavy network traffic leads to network break-down
got my Pinebook Pro few days ago, so complete newbie with Arm64 & Co (including ArchLinux/Manjaro, I'm more of a Fedora user normally).
Anyway, connection over Wifi to my network works (ping etc), but anything slightly heavy (loading a webpage in Firefox or calling pacman to refresh the cache or install a package) leads after a very little while (less than a minute for sure) to a complete breakdown of the whole network, not only for the PBP, but also for any other device, even connected to the LAN or another Wifi.
I had "Enabled Smart Connect - Let the router intelligently select the best 2.4 GHz or 5 GHz WiFi band for your WiFi connections. Smart Connect requires that the 2.4 GHz and 5 GHz WiFi networks use the same WiFi network name (SSID), security options, and password." Having read about issues with the 2.4GHz band at https://wiki.pine64.org/index.php/Pinebo...h_and_WiFi I've switched off this option and give a specific name to the 5GHz network, and started only using this one. BUT this didn't make any difference and I'm a bit at the end of my ideas what I can do.
Perhaps important, the Wifi router is a Nighthawk® X4S R7800 running in AP Mode against another router (TP-Link TL-WDR4300 v1 with OpenWrt 22.03.3 r20028-43d71ad93e / LuCI openwrt-22.03 branch git-22.361.69894-438c598), which is used since years without any issue.
Thanks, Eric
More heavy network traffic leads to network break-down - by ericzolf - 09-24-2023, 01:38 AM
  Manjaro network problem late 2023 acruhl 1 383 01-19-2024, 11:32 PM
  Network shared folder discovery (smb4k) solostian 10 8,771 12-06-2021, 07:27 AM
Last Post: solostian
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 1,372 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
  Network settings, where to find the config files? hvdkooij 1 2,899 11-20-2020, 02:47 PM
Last Post: xyzzy
  pinebook pro manjaro xfce pacman network error thumbsup 1 3,052 07-11-2020, 02:32 PM
Last Post: thumbsup
  Crash in brcmfmac joining WPA2 network rillian 7 9,604 02-03-2020, 12:36 AM
Last Post: vrabac
  Network Manager on Deb Atton 5 5,601 12-10-2019, 04:10 AM
Last Post: Atton
