MMS message being displayed delayed
(09-14-2023, 07:27 AM)alaraajavamma Wrote:
(09-13-2023, 04:22 PM)car46999 Wrote: Yes, same APN settings in System, "RESELLER" for Puretalk. That is the only data field in system settings, in Chatty I have the Puretalk MMSC entered and the proxy (minus the port, as it didn't seem to make a difference).
It seems to have worked all day, so it is possible I received an MMS message prior to setting it up in Chatty. Would that message eventually expire and it start working correctly?
I just listed the files in ~/.mms/modemmanager/ and two files were just created that are dated Dec 31 1969. I cannot say exactly when they were created, but it would have been within the last 20-30 minutes, and within the same time period of receiving a test text back from an MMS group text.
How long should the files in that directory be there? Is it for incoming only or both in and out?
Files are for incoming and for outgoing both. When everything goes perfectly well those files will be removed in seconds after the mms has been sent/received - sometimes it might take bit longer but most of the times it is seconds.
You migth want to join to the matrix room because it seems that your carrier is doing something funny:
https://matrix.to/#/!ZpAVqiESnSBiERBbjK:matrix.org
Okay I will look into joining
Thanks for the advice
MMS message being displayed delayed - by car46999 - 09-12-2023, 10:42 PM
RE: MMS message being displayed delayed - by car46999 - 09-14-2023, 06:58 PM
  Pine phone Junior, message phone ? bcnaz 22 14,535 09-30-2021, 12:04 AM
  Germany batch will be delayed vicky 80 101,065 10-01-2020, 12:23 AM
Thumbs Up Phone arrived; a message of thanks ReleaseTheGeese 2 3,490 07-09-2020, 08:15 AM
Last Post: ReleaseTheGeese
