NextCloud Gnome Mobile
(09-06-2023, 03:32 AM)Uturn Wrote: My Problem with Karlender App is that it syncs forever since install, and adding my nextcloud credentials changes nothing. This Karlender syncs and syncs and shows zero connected calendars.
Maybe you can try gnome-calendar? It should work and also it will sync the connection directly from the system settings.
You need to "scale-to-fit" gnome-calender because it does not scale perfectly.
Also if you have 2fa in your account you might need to generate app password
NextCloud Gnome Mobile - by Uturn - 09-01-2023, 01:11 AM
RE: NextCloud Gnome Mobile - by alaraajavamma - 09-01-2023, 06:02 AM
RE: NextCloud Gnome Mobile - by Uturn - 09-06-2023, 03:32 AM
RE: NextCloud Gnome Mobile - by alaraajavamma - 09-06-2023, 05:22 AM
RE: NextCloud Gnome Mobile - by Uturn - 12-03-2023, 07:54 AM
  Gnome mobile user641 1 750 01-06-2024, 11:06 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 933 10-03-2023, 06:32 PM
  Software app in postmarket gnome shell Uturn 1 710 09-06-2023, 05:27 AM
Last Post: alaraajavamma
Question Always Use Mobile Data DingDangDoong 4 2,049 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,461 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,218 11-06-2022, 06:41 PM
Last Post: Chief
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,401 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  gnome-firmware-updater not found (mirrors) wizardry 1 1,468 03-22-2022, 12:30 PM
Last Post: wizardry
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 2,057 03-23-2021, 10:25 AM
Last Post: Egolep
  Angelfish on Plasma Mobile not working fernando_c_m 4 6,188 09-06-2020, 10:31 PM
Last Post: bcnaz
