wasp-os status
Information
Here is my notes from today, going from InfiniTime to WASP OS and back to InfiniTime.
PineTime is FOSS SmartWatch.
Website: https://www.pine64.org/pinetime/
1) InfiniTime
This is default software, based on FreeRTOS and C++.
Wiki: https://wiki.pine64.org/wiki/PineTime
1. Install F-Droid to Android smartphone https://f-droid.org
2. From F-Droid, install GadgetBridge.
3. Upgrade InfiniTime https://wiki.pine64.org/wiki/Upgrade_Pin...Time_1.0.0
2) WASP OS
This is alternative software, with MicroPython.
2a) WASP OS Simulator
At Debian 12:
sudo apt install -y \
  wget git build-essential unzip libsdl2-2.0-0 \
  python3-click \
  python3-cryptography \
  python3-cbor \
  python3-gi \
  python3-numpy \
  python3-pexpect \
  python3-pil
  python3-pydbus \
  python3-Pillow \
  python3-serial \
  python3-pygobject \
  python3-sdl2 \
  python3-pytest \
  tomli \
  ubertooth-firmware-source
git clone https://github.com/wasp-os/wasp-os
cd wasp-os
make sim
2b) WASP OS to PineTime SmartWatch
https://wiki.pine64.org/wiki/Switching_y...nd_Wasp-os
1. Install with GadgetBridge (I'm using GadgetBridge Nightly, by adding URL to F-Droid https://freeyourgadget.codeberg.page/fdroid/repo/ )
2. Currently only official release of WASP OS works, I read it from some issue. I did not try any other version.
3. With Android webbrowser, download wasp-os-4.1.zip from https://github.com/wasp-os/wasp-os/releases , and unzip it at Android.
4. With GadgetBridge, connect to PineTime, and then use right top 3 dots / File Installer to install wasp-os-0.4.1/wasp-os-4.1/build-pinetime/reloader-mcuboot.zip
5. When there is arrow, and display is not flashing white pinecone, connect from GadgetBridge to PineTime this different way.
6. Click bottom + (blue background, white +)
7. Click Discovery and Pairing options
8. Enable with setting slider to right these: CompanionDevice Pairing, Discover unsupported devices
9. Click left top arrow back (white arrow, red background)
10. Click Start Discovery
11. Click PineDFU. It will copy MAC address to clipboard.
12. Click left top arrow back (white arrow, red background)
13. Click left top hamburger menu
14. Click Error finding (that is below settings option)
15. Click 9th from bottom "Add test device manually". Red button, white text.
16. Remove text from input field. Paste with Ctrl-v from clipboard, or hold at in put field and paste.
17.  From pasted text, remove beginning of text, only leave MAC address like 12:34:56:78
18. From dropdown menu, select PineTime. Click Add button, to add device.
19. Click left top arrow back (white arrow, red background)
20. Click right 3 dots / File Installer / Add file wasp-os-0.4.1/wasp-os-4.1/build-pinetime/micropython.zip
21. Now you have WASP OS.
3) From WASP OS back to Infinitime
1. Install reloader-infinitime-recovery-0.14.1.zip
2. After that, connect to PineTime with pairing options 2 at top enabled. Connect without pairing.
3. Right 3 dots / File Installer / Install newest pinetime-mcuboot-app-dfu-1.13.0.zip downloaded from https://github.com/InfiniTimeOrg/InfiniTime/releases
4. Right 3 dots / Remove device
5. Click bottom + (blue background, white +)
6. Click Discovery and Pairing options. Only top one slider enabled to right.
7. Click left top arrow back (white arrow, red background)
8. Connect to InfiniTime with pairing. Type yellow number to GadgetBridge. If PineTime display turns off, click button once to show yellow pairing number again. After pairing, slide PineTime display down, to show time. Now time will sync from Android to PineTime.
wasp-os status - by erikzoltan - 08-23-2023, 06:57 PM
RE: wasp-os status - by GaryM - 08-24-2023, 09:46 PM
RE: wasp-os status - by erikzoltan - 08-27-2023, 12:03 PM
RE: wasp-os status - by GaryM - 08-28-2023, 04:59 PM
RE: wasp-os status - by erikzoltan - 08-31-2023, 09:47 AM
RE: wasp-os status - by xet7 - 10-06-2023, 11:32 AM
  Wasp-os editing main.py Mpoint 4 2,918 08-07-2021, 02:34 PM
Last Post: danielt
Sad wasp simulation error pratyush049 1 3,108 06-24-2020, 06:51 AM
Last Post: danielt
