Pinephone won't boot.
(08-17-2023, 11:49 AM)spha Wrote: Pinephone screen stopped working. The system starts but the screen is black. When starting the jumpdrive, the screen is bright gray, but after an hour of charging, nothing has changed. The battery voltage is 3.76 volts. I have tried different operating systems and chargers. The last time it worked, I turned it off by holding the power button and put it on the table.
Which Jumpdrive image did you flash? Jumpdrive is not supposed to show a gray screen, instead it should show this screen: https://wiki.pine64.org/images/1/1a/Jumpdrive.jpg
The rest of the symptoms describe a drained battery, maybe beyond the point of saving. Mind that in this state, charging it for only one hour in Jumpdrive is not sufficient, at this state it will charge very slowly and it is required to charge it multiple hours until the drained battery takes some charge again.
Pinephone won't boot. - by spha - 08-17-2023, 11:49 AM
RE: Pinephone won't boot. - by fxc - 08-17-2023, 02:31 PM
RE: Pinephone won't boot. - by Kevin Kofler - 08-17-2023, 04:47 PM
RE: Pinephone won't boot. - by spha - 08-18-2023, 12:56 AM
RE: Pinephone won't boot. - by fxc - 08-18-2023, 01:28 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 01:38 AM
RE: Pinephone won't boot. - by fxc - 08-18-2023, 02:33 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 02:45 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 05:09 AM
RE: Pinephone won't boot. - by fxc - 08-19-2023, 05:19 AM
RE: Pinephone won't boot. - by spha - 08-20-2023, 02:44 AM
RE: Pinephone won't boot. - by mikehenson - 08-18-2023, 08:15 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 08:48 AM
RE: Pinephone won't boot. - by Richy_T - 05-15-2024, 10:31 PM
  Pinephone boot. Richy_T 5 262 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,794 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 1,008 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 498 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 340 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 112,599 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,029 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 727 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,702 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 588 12-26-2023, 02:42 PM
Last Post: shengchieh
