Article: NuttX RTOS for PinePhone: Feature Phone UI in LVGL, Zig and WebAssembly
#65
(09-09-2023, 05:34 AM)Kevin Kofler Wrote: (Well, technically, some hardware also allows you to remap its DMA to a different address, provided by you, usually under some constraints such as a minimum alignment, but I do not know whether this is possible on the PinePhone.)
Thanks Kevin, yes, this is what I try to do, DMA accessed, direct memory without a driver, and no blit. I hope this will allow me eventually some hardware GPU acceleration, if I ever find documentation for the openVG, or if not just access to the 3 planes and mixers for some UI effects.  Lets see Smile  Currently my USB micro SD card adapter broke, so testing is on hold for a few days, and it has prompted me that I really should have an extension cable for the PP card slot to avoid too much ware n tear during development, but struggling to find one locally.
After that I might have another go with the audio routing, now that I have so much of the SoC working in Zig I feel a bit more confident to try again.  Unless the PineTab-V comes back in stock before then! Smile
btw I did see mention of some kind of recovery mode, 'FEL Mode' that sounds useful for development, but no way to switch the PP into this mode?
RE: Article: NuttX RTOS for PinePhone: Feature Phone UI in LVGL, Zig and WebAssembly - by WhiteHexagon - 09-09-2023, 09:49 AM
  Using Signal on PinePhone in mid-2023? dante404 47 14,087 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,590 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,206 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 547 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,517 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,900 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,164 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,199 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,058 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,466 10-24-2023, 08:57 AM
