GPIO on Ayufan 0.9.14 Build
(04-22-2023, 04:15 PM)diederik Wrote:
(04-22-2023, 11:16 AM)Thisone Wrote: I'm trying to use the GPIOs on the Ayufan Ubuntu Build (bionic-mate-rockpro64-0.9.14-1159-armhf), but can't seem to get it working.
Apperently the libgpiod uses /dev/Gpiochip0, which is not on this version.
Problem is, that i have to use a Desktop Image, which supports the Pine Touchdisplay, for the Rest of the Program, and i can't seem to get the other Versions (like focal-mate-rockpro64-0.10.12-1184-armhf) running.
So is there a way to use the GPIO pins on the 0.9.14 Version?
Debian kernel 6.1.20-2 (and later) support the Pine Touchdisplay, so if you install Debian Bookworm, it should all work*?
I think you're needlessly limiting yourself by only looking at Ayufan's images ... which also seem (a bit) dated.
*) don't use guided partition with using the whole disk (option 2 iirc) as that would create an unbootable system (as 1st partition starts at 1MB, overwriting u-boot). This is a bug in d-i
So i just have to Flash the Debian image (https://d-i.debian.org/daily-images/arm6...399.img.gz) on the eMMC, without the partition (https://d-i.debian.org/daily-images/arm6...ion.img.gz) to get it working? (files are from the Getting started page).
I can't seem to get the debian Image working on the Rockpro. What Steps do I have to take, to get it working?
GPIO on Ayufan 0.9.14 Build - by Thisone - 04-22-2023, 11:16 AM
RE: GPIO on Ayufan 0.9.14 Build - by diederik - 04-22-2023, 04:15 PM
RE: GPIO on Ayufan 0.9.14 Build - by Thisone - 04-23-2023, 06:06 AM
RE: GPIO on Ayufan 0.9.14 Build - by diederik - 04-23-2023, 08:05 AM
RE: GPIO on Ayufan 0.9.14 Build - by Thisone - 04-23-2023, 07:31 AM
RE: GPIO on Ayufan 0.9.14 Build - by Thisone - 04-23-2023, 09:58 AM
RE: GPIO on Ayufan 0.9.14 Build - by Thisone - 04-23-2023, 11:11 AM
RE: GPIO on Ayufan 0.9.14 Build - by diederik - 04-23-2023, 01:32 PM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,497 07-14-2023, 04:22 AM
Last Post: hunderteins
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,503 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  ayufan kernel update unbootable TheHunter 2 3,272 03-12-2021, 05:17 PM
Last Post: LMM
Question Ayufan RockPro64 updates? hemertje 3 6,328 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 5,487 10-22-2020, 01:12 PM
Thumbs Up First Manjaro Mainline build! Luke 10 16,196 10-20-2020, 04:29 AM
Last Post: vfr400racer
  Gpio indicator of drive activity possible? Mentaluproar 1 2,616 08-11-2020, 11:04 PM
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 3,631 04-17-2020, 02:53 AM
Last Post: Thra11
  New Pre-release 0.10.9 from Ayufan Bullet64 0 2,430 04-09-2020, 06:49 AM
Last Post: Bullet64
  Ayufan 5.4.0 rc1 release - cannot boot Mentaluproar 2 5,265 01-05-2020, 02:39 PM
Last Post: mmiigg
