Soquartz-cm4io emmc with usb host
Hello all,
I'am trying to use a soquartz module on a cm4-io board, with a emmc chip on it (mmcblk1). I'am able to install, manjaro, armbian, pleb. I'am able to boot on the emmc, but the usb port won't work except when I have a sdcard inserted in my cm4io board.
Is there a way to get usb working without sd card?
Here's some informations:
Without sdcard:
Quote:lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
With sdcard:
Quote:lsusb
Bus 001 Device 013: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Here's the udev event on card insertion:
Quote:udevadm monitor
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[6269.749066] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa (mmc)
KERNEL[6269.753961] add      /devices/virtual/bdi/179:0 (bdi)
UDEV  [6269.769249] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa (mmc)
KERNEL[6269.771594] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 (block)
KERNEL[6269.772159] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 (block)
UDEV  [6269.772502] add      /devices/virtual/bdi/179:0 (bdi)
KERNEL[6269.772893] bind    /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa (mmc)
UDEV  [6269.901933] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 (block)
KERNEL[6269.934898] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
KERNEL[6269.969263] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
KERNEL[6269.969411] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.033728] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.034182] unbind  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.034503] remove  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.034771] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.056507] add      /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 (block)
UDEV  [6270.059122] bind    /devices/platform/fe2b0000.mmc/mmc_host/mmc0/mmc0:aaaa (mmc)
KERNEL[6270.129216] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
KERNEL[6270.129397] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.193638] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
KERNEL[6270.193788] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.197201] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.201544] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.205151] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.208560] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.211622] unbind  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.213159] remove  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.217478] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.221733] change  /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
UDEV  [6270.225214] add      /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.228709] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0 (usb)
UDEV  [6270.232849] bind    /devices/platform/fcc00000.usb/xhci-hcd.9.auto/usb1/1-1 (usb)
Thank you in advance for your answers and solutions.
Best Regards.
Soquartz-cm4io emmc with usb host - by louisvinc - 02-12-2023, 12:20 PM
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 499 11-19-2023, 01:04 AM
Last Post: stormwyrm
  SOQuartz with Waveshare CM4 fan heatsink stormwyrm 1 451 11-18-2023, 01:35 PM
  SOQuartz BLADE 3D server rack screws agriffith2134 1 638 08-14-2023, 02:23 PM
Last Post: agriffith2134
  eMMC endurance O1ez 2 1,634 09-27-2022, 04:43 AM
Last Post: O1ez
  DeskPi Super6C CM4 board with the SOQuartz adamfowleruk 5 4,184 08-09-2022, 03:22 PM
Last Post: tizilogic
  SOQuartz ATX Baseboard nixcamic 0 1,555 02-05-2022, 11:55 PM
Last Post: nixcamic
  Lamenting the fact that only 2 lanes of LVDS are exposed on SOQuartz evankrall 0 1,440 12-13-2021, 01:07 PM
Last Post: evankrall
