Reducing Android Image download size.
I was wondering if it would be possible to change the compression used for the android images away from zip files. This is to greatly reduce the overall file size on download. For example the
16GB image for Android version 5.1.1 released on July 11, 2016 is about 641 Megabytes in it's current zip format. If one changes the file type to 7-zip ( http://7-zip.org/ ) it's possible to further reduce the image to about 487 Megabytes. This is file that is about 30% smaller and should help with lowering bandwidth usage to acquire the image.
Just as a quick note I was using 7zip version 15.14 and I had the following Compression settings...
NOTE 1: The compression settings I used means that any system capable of running Microsoft Windows 7 should be able to use 7-zip to decompress the file. The main requirement is to have at least 256MB of ram.
NOTE 2: I used a 8-core system for the compression, however any desktop computer can decompress the file as long as they meet the minimum software requirements.
Reducing Android Image download size. - by KPhillisJr - 07-17-2016, 10:04 PM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,807 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,830 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,886 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,007 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,083 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,356 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,687 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,628 02-10-2019, 07:44 PM
Last Post: mmmarcus
