PBP became not-bootable after replace new mainboard.
(12-12-2022, 01:54 PM)wdt Wrote: >I think I have received a fault production... right?
wrong, it seems there are, all of a sudden, a lot of bad uboots out there
armbian or manjaro??, it is not clear which you have installed
anyway, if you disable/remove emmc it will likely boot from SD
Once you see splash screen, uboot is done, compleatly  out of the picture
So, something in the OS is also not right  (for new mb?)
Oh. I see.
Once I tried to boot Armbian with uSD, the splash screen appeared and ring just keep circles around 1 hour.
maybe... I think it happened by the uSD speed because it is a class-4 one.
I will try another with class-10 faster one
Thank you for ensuring that is not production fault : )
RE: PBP became not-bootable after replace new mainboard. - by lotsofstars - 12-12-2022, 06:09 PM
  Unable to make a bootable microSD card myself600 15 5,724 09-27-2022, 01:45 PM
Last Post: myself600
  100% SD bootable img untitled 9 3,934 08-22-2022, 12:15 PM
Last Post: snorwood
  Making an SD card bootable bero 1 2,571 11-19-2020, 12:03 PM
Last Post: ab1jx
