12-03-2022, 06:12 AM
It depends on what you do with PiOS. If you only use the graphical desktop environment, you might be perfectly happy with Manjaru. If you used the command line, then Debian will suit you just fine. Otherwise, see the wiki; there are a plethora of different operating systems you can use. BTW, many people use a Arch but I use NetBSD.
:wq
[ SRA accepts you ]
[ SRA accepts you ]
