Most stable Pinephone OS
#19
(12-05-2022, 05:19 PM)Zebulon Walton Wrote:
(12-05-2022, 03:49 PM)Chief Wrote: I just updated my Arch Linux Phosh as I was looking for a certain update. First as you know I backed everything up and then did update. All is working well and I wont touch anything update until a situation arises where I need something updated.
At present I am working on my other phone with Arch Plasma. Still plenty of work required there and I update that all the time. That phone is not critical but my Arch Phosh phone does have critical info on it so I must protect that.
Good luck Zeb with getting the calls back audio.
I have Arch on the SD card that I'm using. It basically works so I'm not going to update it. The only issues I noticed is that as with Mobian, bluetooth audio doesn't work and if I use a wired headset, that has to be plugged in after dialing the call. (The microphone does not work if you plug the headset in first.)
I think having a "known to work" SD card as a backup, as well as an image backup of the eMMC, is a must if using the Pinephone as a daily driver as I've been doing for about a year and a half now. It's only recent Mobian updates that I've found to be really problematical. Hopefully I'll get lucky with the call audio problem with upcoming updates but if not I have a working image backup at the ready.
The basic reason I think the audio doesn't work right is because the o.s. takes priority and not the call app.
This is why I suggested to Pine64 to separate the call app from ANY o.s. so the phone works separately.
This way the phone could always work regardless of o.s. installed. Until this is done I suspect that phone calls
will always be hit and miss.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
Most stable Pinephone OS - by karcdaeh - 11-28-2022, 11:50 AM
RE: Most stable Pinephone OS - by fxc - 11-28-2022, 02:59 PM
RE: Most stable Pinephone OS - by karcdaeh - 11-29-2022, 12:43 PM
RE: Most stable Pinephone OS - by Chief - 11-28-2022, 05:19 PM
RE: Most stable Pinephone OS - by karcdaeh - 11-29-2022, 12:52 PM
RE: Most stable Pinephone OS - by Chief - 11-30-2022, 11:10 AM
RE: Most stable Pinephone OS - by mikehenson - 11-29-2022, 08:53 AM
RE: Most stable Pinephone OS - by karcdaeh - 11-29-2022, 12:54 PM
RE: Most stable Pinephone OS - by Anna - 12-03-2022, 11:40 AM
RE: Most stable Pinephone OS - by karcdaeh - 12-03-2022, 02:07 PM
RE: Most stable Pinephone OS - by Zebulon Walton - 11-29-2022, 04:26 PM
RE: Most stable Pinephone OS - by shulamy - 11-29-2022, 11:37 PM
RE: Most stable Pinephone OS - by dachalife - 11-30-2022, 12:20 AM
RE: Most stable Pinephone OS - by Zebulon Walton - 12-03-2022, 02:06 PM
RE: Most stable Pinephone OS - by Chief - 12-04-2022, 05:19 PM
RE: Most stable Pinephone OS - by Zebulon Walton - 12-05-2022, 07:07 AM
RE: Most stable Pinephone OS - by Chief - 12-05-2022, 03:49 PM
RE: Most stable Pinephone OS - by Zebulon Walton - 12-05-2022, 05:19 PM
RE: Most stable Pinephone OS - by Chief - 12-06-2022, 01:49 PM
RE: Most stable Pinephone OS - by Uturn - 12-07-2022, 05:00 AM
RE: Most stable Pinephone OS - by gregb49 - 12-09-2022, 06:09 AM
  Pinephone boot. Richy_T 4 121 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 895 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 448 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 301 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,050 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,950 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 685 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,590 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 557 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,809 12-22-2023, 03:44 PM
