Usbnet via USB-C on PBP?
(09-25-2023, 05:23 AM)DrYak Wrote: In my experience, the PineBook Pro has some trouble negociating what should go (USB3, Display port) of the various pins in alternate mode.
Usually, there's one side which goes much better.
Most modern USB-C to LAN are going to be USB3 and thus affected by this (including the dock. In one orientation, only the USB2 + charging works reliably, in the other orientation, USB3 (and LAN) works too).
Ah, genius! This is exactly the issue, I tried with a LAN adapter and with a hub, and the results are there: in one direction, the LAN isn't recognized, in the other it works flawlessly; and the hub is recognized as 2.1 hub in one direction, and 3.1 in the other (and the connected LAN works). I can't mark this conversation as resolved because I didn't start it, but it is resolved for me! Actually, this should be documented in the Troubleshooting Wiki.
Usbnet via USB-C on PBP? - by bircoph - 11-05-2022, 05:52 PM
RE: Usbnet via USB-C on PBP? - by ericzolf - 09-24-2023, 10:57 AM
RE: Usbnet via USB-C on PBP? - by fxc - 09-24-2023, 02:34 PM
RE: Usbnet via USB-C on PBP? - by ericzolf - 09-24-2023, 11:59 PM
RE: Usbnet via USB-C on PBP? - by DrYak - 09-25-2023, 05:23 AM
RE: Usbnet via USB-C on PBP? - by ericzolf - 09-25-2023, 11:19 AM
RE: Usbnet via USB-C on PBP? - by bircoph - 11-15-2023, 10:28 PM
RE: Usbnet via USB-C on PBP? - by wdt - 11-16-2023, 01:39 AM
