My Hacky ethernet fix
This worked for me, I cant guarantee it will work for anyone else's issue but if you have a spare ethernet cable abut then it cant do any harm.
I haven't been able to use my Ethernet properly since getting the board, I found a work around where I route it through to 100mbit power line adapters and the 100mbit ports get it working but soon as I plug it in to my gigabit router it stops. I cant change the ports to fast Ethernet 100mbit either, but this isnt ideal so i found a better solution.....
[Image: jc_gigabit_image006.gif]
My solution is to mod the ethernet cable which works perfectly, I used a standard cat5 straight through cable
Opened it up and cut all of the blue and brown wires, so thats 4,5,7 and 8 secure the wire with electrical table and you're sorted, this will be in 100mbit mode and once a fix comes out you will be able to solder the wires or use another cable to use gigabit again.
[Image: 20160713_094443.jpg][Image: 20160713_094450.jpg]
My Hacky ethernet fix - by anarchyuk - 07-13-2016, 02:51 AM
RE: My Hacky ethernet fix - by clarkss12 - 07-13-2016, 08:37 AM
RE: My Hacky ethernet fix - by g_t_j - 07-13-2016, 02:00 PM
RE: My Hacky ethernet fix - by clarkss12 - 07-13-2016, 02:43 PM
RE: My Hacky ethernet fix - by anarchyuk - 07-14-2016, 01:12 AM
RE: My Hacky ethernet fix - by clarkss12 - 07-14-2016, 02:18 PM
RE: My Hacky ethernet fix - by anarchyuk - 07-15-2016, 09:40 AM
RE: My Hacky ethernet fix - by User 4127 - 07-14-2016, 01:32 PM
RE: My Hacky ethernet fix - by curiousgally - 07-18-2016, 11:03 AM
RE: My Hacky ethernet fix - by User 4127 - 07-18-2016, 11:10 AM
RE: My Hacky ethernet fix - by Summons - 07-18-2016, 01:30 PM
RE: My Hacky ethernet fix - by Boring - 09-02-2016, 10:04 AM
RE: My Hacky ethernet fix - by FlyersRule - 09-02-2016, 12:24 PM
RE: My Hacky ethernet fix - by kermitas - 09-02-2016, 01:52 PM
RE: My Hacky ethernet fix - by moondark - 09-04-2016, 11:47 AM
RE: My Hacky ethernet fix - by pfeerick - 09-04-2016, 11:47 PM
RE: My Hacky ethernet fix - by kermitas - 09-05-2016, 01:13 AM
RE: My Hacky ethernet fix - by ayufan - 09-05-2016, 12:53 PM
RE: My Hacky ethernet fix - by kermitas - 09-06-2016, 02:54 AM
RE: My Hacky ethernet fix - by MarkHaysHarris777 - 09-06-2016, 07:06 AM
RE: My Hacky ethernet fix - by Mathieu147 - 11-20-2016, 04:22 AM
RE: My Hacky ethernet fix - by waldo - 11-20-2016, 12:01 PM
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 4,582 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 4,095 12-07-2017, 05:09 AM
Last Post: daniele
  No Ethernet on Andriod rvalecruz 5 6,746 05-05-2017, 01:59 AM
Last Post: Quezbeme
  Lost Ethernet hatman28 13 17,156 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 23,956 10-29-2016, 04:31 AM
Last Post: joe
  Android Ethernet Problem a5467021 11 17,317 08-01-2016, 07:41 PM
Last Post: a5467021
  Can we force the ethernet link to 100mbps? moondark 10 15,244 07-26-2016, 10:56 AM
Last Post: kermitas
  Android Issues; 4K, Ethernet, Plex kikootwo 6 7,649 07-10-2016, 12:23 AM
Last Post: yusijs
  Android and Ethernet W1SPY 54 71,538 07-07-2016, 01:48 AM
Last Post: Absum
  Ethernet not working on Android (my dicoverys) Apicalis 9 15,455 06-15-2016, 02:34 AM
Last Post: Apicalis
