Unable to set default apps
(12-04-2022, 09:10 AM)Veraendert Wrote:
(12-02-2022, 06:57 PM)Barugon Wrote: This is still an issue. Sad
Same here. You're not alone.
Workaround is to install Nautilus and plug in mouse.
Open Nautilus and choose some file with file type for your needs (for example .pdf) and then press right button of the mouse.
It will open dialog where you can choose the default application to open pdf files Smile.
You can also edit mimeapps.list from your /home/user/.config folder but the upper one is easier solution.
Unable to set default apps - by Barugon - 09-22-2022, 04:01 PM
RE: Unable to set default apps - by Barugon - 09-23-2022, 05:18 PM
RE: Unable to set default apps - by olyavi - 09-24-2022, 06:13 AM
RE: Unable to set default apps - by Barugon - 09-24-2022, 03:54 PM
RE: Unable to set default apps - by Barugon - 09-27-2022, 02:14 PM
RE: Unable to set default apps - by Barugon - 12-02-2022, 06:57 PM
RE: Unable to set default apps - by Veraendert - 12-04-2022, 09:10 AM
RE: Unable to set default apps - by alaraajavamma - 12-04-2022, 12:28 PM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 455 11-22-2023, 10:16 AM
Last Post: zetabeta
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 2,385 05-28-2023, 10:54 PM
Last Post: Avisando
  Help with ssh and setting default apps jojuma 2 1,712 09-10-2022, 07:55 AM
Last Post: jojuma
  closing apps rather than leaving them running (phosh) lordearl 7 6,257 02-03-2022, 09:14 PM
Last Post: parry
  What is the default pin!? ThatWasLeftHanded 3 5,522 09-08-2021, 09:01 AM
Last Post: walter1950
  Disabe Bluetooth by default Alejandro.SU 1 2,600 11-09-2020, 10:59 AM
Last Post: Lousy Fisherman
  What is default password? quixote 6 17,981 11-03-2020, 08:55 AM
Last Post: wibble
  Resize apps for postmarket OS zeb11 8 10,758 09-26-2020, 04:21 PM
Last Post: ragreenburg
  Unable to mount root partition PostmarketOS lanawwas 0 2,883 09-06-2020, 07:42 AM
Last Post: lanawwas
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 3,025 08-24-2020, 06:34 AM
Last Post: PureTryOut
