Tow-boot on Pinephone beta edition
(09-06-2022, 10:10 AM)mark1250 Wrote: When I went to install tow-boot onto my Pinephone A64, I wasn't really paying attention to the file I downloaded. I just used xzcat and piped it to dd and wrote it to my SD card. And, it didn't work. After scratching my head a bit, I finally realized that the file you download contains 2 disk images and is not directly flashable.
When you download tow-boot from github: https://github.com/Tow-Boot/Tow-Boot/rel...005.tar.xz you have to extract it.
I used: unxz pine64-pinephoneA64-2021.10-005.tar.xz
Then  untar the tar file: tar -xf pine64-pinephoneA64-2021.10-005.tar
- There is probably a single command that will do this, but I was too lazy to look it up.
You'll end up with a folder with 2 .img files. dd or etcher... the mmcboot.installer.img image file to your SD card. Pop the SD card into your Pinephone and the tow-boot installer should boot and an install menu will appear on the phone screen.
Because the Pinephone A64 looks for the boot loader on the SD card then eMMC, it will boot off an SD card that has u-boot on it. If you don't want this you'll have to remove u-boot from the SD card. There are instructions on the wiki: https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
 did those instractions work for you ?
 ezik
Tow-boot on Pinephone beta edition - by saddamus - 09-04-2022, 02:39 AM
RE: Tow-boot on Pinephone beta edition - by shulamy - 09-06-2022, 11:06 AM
RE: Tow-boot on Pinephone beta edition - by Chief - 09-06-2022, 01:03 PM
  Pinephone boot. Richy_T 4 85 Yesterday, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 849 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 423 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 289 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,748 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,925 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 666 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,503 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 542 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,786 12-22-2023, 03:44 PM
