New phone
(06-25-2022, 05:31 PM)totilele Wrote:
(06-23-2022, 11:39 AM)fxc Wrote:
(06-23-2022, 12:23 AM)totilele Wrote:
(06-22-2022, 02:59 PM)fxc Wrote:
(06-22-2022, 11:26 AM)totilele Wrote: Yes, I'm thinking of installing Mobian on the SD card (if I manage).
In fact, yesterday I faced another problem - somehow the phone screen started to turn on and off (like 1 second it is lighted and the keeps disappearing, if I do not keep pressing the surface. I'm not sure what the problem is.
I tried using (it's actually KDE Plasma as the internal OS) it, but it's been quite difficult.
One more problem - the Internet with SIM card in doesn't work (only with WiFi), which is again not what I want.
At the moment there seem to be so many problems, the biggest of them being not being able to use the phone because the screen keeps disappearing.
That sounds like the phone screen timeout is 0, which is also why holding a finger on the screen keeps it alive. Is that on Plasma Mobile by any chance? It used to be a bug in old releases.
yes, KDE Plasma. Strangely enough, now it works fine (just today, but no idea if that will last).
I'd like to update the system, but somehow when I see 'Updates available' it says the total size of updates is 0 ( even though it's 666 updates available).
Would recommend to update via the command line to see the actual issue, "sudo pacman -Syu".
Thank you. I've got more or less many things done, thanks to all of your support and answers. Very appreciate it. The screen timeout issue seems to have disappeared by itself somehow, now the only biggest problem is that my mobile data do not work (it actually worked for half a day and then again disappeared).
I googled, but then I found I needed to configure APN settings, yet there are no settings listed for my country.
The APN settings will be on the website of your provider. They are also used in Android and the iPhone (for example if not detected properly automatically), so that's not specific to the PinePhone.
New phone - by totilele - 06-14-2022, 08:44 AM
RE: New phone - by wibble - 06-15-2022, 02:16 AM
RE: New phone - by totilele - 06-17-2022, 05:51 AM
RE: New phone - by totilele - 06-17-2022, 05:56 AM
RE: New phone - by totilele - 06-17-2022, 06:57 AM
RE: New phone - by wibble - 06-20-2022, 03:14 AM
RE: New phone - by totilele - 06-20-2022, 11:26 AM
RE: New phone - by wibble - 06-20-2022, 01:05 PM
RE: New phone - by totilele - 06-20-2022, 06:28 PM
RE: New phone - by wibble - 06-21-2022, 02:03 AM
RE: New phone - by totilele - 06-22-2022, 11:26 AM
RE: New phone - by fxc - 06-22-2022, 02:59 PM
RE: New phone - by totilele - 06-23-2022, 12:23 AM
RE: New phone - by fxc - 06-23-2022, 11:39 AM
RE: New phone - by totilele - 06-25-2022, 05:31 PM
RE: New phone - by fxc - 06-26-2022, 01:11 AM
RE: New phone - by dachalife - 06-21-2022, 01:53 PM
RE: New phone - by totilele - 06-28-2022, 04:39 AM
  Looking for the "non-phone" OS wakyct 7 1,500 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,288 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 1,068 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,187 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 4,095 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 771 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 745 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,298 03-15-2023, 05:33 AM
Last Post: anonymous
  pine phone external speaker AnAbolitionist 9 3,666 02-08-2023, 01:11 AM
Last Post: robb777
  new to pine phone and struggling neverdimed 8 3,031 11-25-2022, 05:01 PM
Last Post: neverdimed
