Phosh 0.20 beta on mobian
To install phosh 0.20 beta on mobian you need to:
Go to https://repo.pureos.net/pureos/pool/main/p/phosh/ and download phosh_0.20.0~beta1-1pureos1_arm64.deb and phosh-mobile-tweaks_0.20.0~beta1-1pureos1_all.deb
Then cd into the directory you downloaded the files into (example: cd ~/Downloads)
Then run sudo dpkg -i *.deb then reboot
You should have phosh 0.20 on your pinephone! (tested on pinephone mobian ce)
Phosh 0.20 beta on mobian - by Anthony1224 - 06-10-2022, 07:43 PM
RE: Phosh 0.20 beta on mobian - by Zebulon Walton - 06-11-2022, 06:29 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,566 2 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,000 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 161 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,085 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Auto start application on Phosh login Zebulon Walton 8 3,497 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  What actions needed to keep on mobian testing user641 3 1,892 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 658 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,071 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,938 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 655 07-05-2023, 03:57 AM
Last Post: paulcarton
