Vibration motor buzzes uncontrollably with call waiting
(05-28-2022, 01:32 PM)jurop88 Wrote:
sudo killall feedbackd
works for me, to the point I aliased it as 'krt' (kill ring tones) in my .bashrc
Cool, thanks!
What I'd really like is to disable call waiting entirely so a second incoming call goes right to voicemail. However the firmware version currently running in my modem does not accept the commands (just reports an error) and apparently it's only possible to disable call waiting that way for 2G and 3G connections anyway. (Those have been discontinued in my area, I'm using 4G.) That topic was covered here on the board in another thread:
https://forum.pine64.org/showthread.php?...#pid105645
Probably at some point gnome-calls will be updated to handle call waiting better but for now just being able to turn off the alert will do.
RE: Vibration motor buzzes uncontrollably with call waiting - by Zebulon Walton - 05-28-2022, 07:32 PM
  Command to test vibration motor? Zebulon Walton 3 2,160 11-12-2023, 08:45 PM
Last Post: zetabeta
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,029 01-04-2023, 06:46 PM
Last Post: 3x5co
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,883 08-02-2022, 03:16 PM
Last Post: treebeard
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,913 06-02-2022, 07:16 AM
Last Post: arkadione
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 3,376 03-01-2022, 10:06 AM
Last Post: bujiraso
  Calls : two rings and call cut and restore. Gribouille 0 900 01-14-2022, 07:40 AM
Last Post: Gribouille
  GDM3 Receiving call on login screen d-.-b 4 3,662 10-07-2021, 06:59 PM
Last Post: d-.-b
  Mobian Constant Vibration tumblingdog 4 4,032 07-10-2021, 02:40 AM
Last Post: aed
  phone call using built it app will not go to bluetooth motox6 3 3,642 06-28-2021, 11:03 AM
Last Post: wibble
  How to clear recent call list? Zebulon Walton 2 2,669 03-25-2021, 07:41 PM
