Can't boot from a microSD card
Right, looks like I was also reading wiki entry for "PinePhone" (not-Pro) on the in the postmarketOS wiki, hence the mixed up info . The volume key info I got from IRC, but that seems to be mistaken too. I actually had no idea about the RE button.
I copied the image the same way I'd create a bootable USB drive using an OS image:
xz --decompress --stdout 20220406-1001-postmarketOS-v21.12-phosh-17-pine64-pinephone-installer.img.xz | sudo dd of=/dev/mmcblk0 bs=4M status=progress
The partitions on the card look like this after copying the data:
$ lsblk | grep -v nvme
NAME        MAJ:MIN RM  SIZE RO TYPE  MOUNTPOINTS
mmcblk0    179:0    0 119.1G  0 disk
├─mmcblk0p1 179:1    0  243M  0 part
├─mmcblk0p2 179:2    0    2G  0 part
└─mmcblk0p3 179:3    0  2.5G  0 part
I'm not sure what the difference between copying an image an "flashing" the drive is -- last time I flashed something was many many years ago and it was usually devices with on-board memory that I needed to flash via USB or serial. I've also never used microSD cards before, so might be missing something that's very obvious to others.
So I'm not pressing the RE button while holding the power button, and the phone simply stays off and doesn't turn on. If I DON'T hold the RE button and just press the power button, it boots up into the eMMC's OS.
As per my timings, I need to hold the power key AT LEAST 11s for the phone to boot, and the screen will only turn on about 10 seconds later, when it's done starting the eMMC's KDE.
Pressing the RE button at any point during the initial 11 seconds results in the phone simply staying off.
Pressing the RE button after the initial 11 seconds usually results in the phone staying off, or booting to the eMMC. When pressing the RE button at the EXACT right moment, it does turn on after a while, but startup fails; the error message was systemd indicating that dependencies for ModemManager had failed and boot stalled.
The tricky part is that I can't figure out when that EXACT moment it; I only got to it by mere chance due to retrying dozens of times (and didn't take a photo of it!). It seems the timings need to be done with PERFECT, or the phone either doesn't boot, or boots off the eMMC.
Can't boot from a microSD card - by WhyNotHugo - 04-09-2022, 12:11 PM
RE: Can't boot from a microSD card - by fxc - 04-09-2022, 05:33 PM
RE: Can't boot from a microSD card - by PineFLOWn - 04-10-2022, 02:50 AM
RE: Can't boot from a microSD card - by WhyNotHugo - 04-10-2022, 04:19 AM
RE: Can't boot from a microSD card - by fxc - 04-10-2022, 04:37 AM
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 46,158 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 1,588 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 19,932 09-10-2023, 03:19 AM
Last Post: fxc
  Factory AOSP image but for your SD card! Danct12 14 8,607 04-03-2023, 06:21 PM
Last Post: strungar
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,870 02-18-2023, 06:14 PM
Last Post: fxc
  tow-boot installation problem techariah 2 1,562 02-16-2023, 02:50 PM
Last Post: techariah
  create tow boot .img fox95 6 3,149 10-21-2022, 11:40 AM
Last Post: fox95
  Phone wont turn on with any SD Card inserted Ausfaller 3 2,480 07-21-2022, 10:20 AM
Last Post: Ausfaller
  No display on early boot after Manjaro update robocone 0 871 07-07-2022, 05:47 AM
Last Post: robocone
  Latest Manjaro-Phosh and Arch-Phosh won't boot grinzie 6 3,951 07-01-2022, 02:01 PM
Last Post: Chief
