Not Bypassing the eMMC
(04-01-2022, 07:29 PM)meansbs Wrote:
(04-01-2022, 09:51 AM)dukla2000 Wrote: OK, I suspect your SDcard is not bootable (boot freezing) and I would recommend you download and flash a Mobian image on that SDcard and give it a try.
Your phone out of the factory contains on the eMMC a bootloader that loads the SDcard first if it can. Otherwise it tries to load Manjaro from the eMMC. No RE needed at any stage. It seems your Manjaro is also duff.
I am not sure about pmOS for PPP but think you actually have to cook your own image with pmbootstrap, which is probably why you are having grief with pmOS.
The 20220327 Mobian image on an SDcard should boot fine using the bootloader from the eMMC. You can then start playing other options like Tow-boot.
Mobian is here: https://images.mobian.org/pinephonepro/w...327.img.gz
Thanks for the help.  Mobian booted with no problems.  I'm in a bit over my head with this stuff, but hopefully I'll figure some of it out.
postmarketOS has no image for the Pro so I assume you simply flashed the completely wrong file previously.
Not Bypassing the eMMC - by meansbs - 03-31-2022, 06:42 PM
RE: Not Bypassing the eMMC - by dukla2000 - 04-01-2022, 09:51 AM
RE: Not Bypassing the eMMC - by meansbs - 04-01-2022, 07:29 PM
RE: Not Bypassing the eMMC - by fxc - 04-02-2022, 06:25 AM
Question The Case of the Vanishing EMMC DieSkaarj 8 2,678 04-20-2023, 03:27 AM
Last Post: DieSkaarj
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,210 12-31-2022, 09:14 AM
Last Post: mburns
  How reflash my eMMC? IHaveALinuxPhone 2 1,446 12-01-2022, 05:39 PM
Last Post: IHaveALinuxPhone
  R U running from eMMC -- If so how? tckosvic 19 12,434 06-14-2022, 08:47 AM
Last Post: bobjrsenior
  Re-flash the emmc For_lack_of_a_better_name 5 2,997 03-31-2022, 08:31 AM
Last Post: ragreenburg
  Please help! Can't install Mobian to eMMC Barugon 4 2,698 03-01-2022, 06:42 PM
Last Post: Barugon
  PPP Explorer Edition - Wipe eMMC The3DmaN 7 5,503 02-01-2022, 04:34 AM
Last Post: dukla2000
  Erasing the eMMC | Pinephone Pro Vermi 4 5,438 01-26-2022, 01:46 PM
