bullseye 11.3 WiFi drivers
Downloaded files from https://github.com/LibreELEC/brcmfmac_sdio-firmware
and placed them in /lib/firmware/brcm/
BCM4345C0.hcd
brcmfmac43455-sdio.bin
brcmfmac43455-sdio.pine64,rockpro64-v2.1.txt
brcmfmac43455-sdio.txt
dmesg |grep firm
[    0.000000] psci: PSCIv1.1 detected in firmware.
[  13.956292] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[  13.976156] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[  14.174721] brcmfmac mmc0:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.bin
[  14.174838] brcmfmac mmc0:0001:1: firmware: failed to load brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.0.txt (-2)
[  14.175925] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[  14.176891] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.0.txt failed with error -2
[  14.256595] brcmfmac mmc0:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.txt
[  15.507776] bluetooth hci1: firmware: direct-loading firmware brcm/BCM4345C0.hcd
Well yes because brcmfmac43455-sdio.pine64,rockpro64-v2.1.txt  was renamed from brcmfmac43456-sdio.pine64,rockpro64-v2.1.txt
as I cound not locate the correct file.
checked armbian too but it looks like there is nothing applicable in /lib/firmware/brcm
Did anyone solve this problem?
location of the correct file? or maybe another way to implement the firmwre?
bullseye 11.3 WiFi drivers - by moserwi - 03-28-2022, 02:01 PM
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,566 08-16-2023, 01:34 AM
Last Post: varac
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,451 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,048 02-17-2022, 12:10 PM
Last Post: flounder
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 7,599 11-08-2021, 02:33 PM
Last Post: TRS-80
  WiFi not working with PCIe SSD installed mikeD 0 1,417 05-25-2021, 07:48 AM
Last Post: mikeD
  Wifi on Manjaro User 19517 0 1,899 09-14-2020, 06:53 PM
Last Post: User 19517
  RockPro64 Slow Ping on WiFi jl_678 0 1,900 05-14-2020, 05:08 PM
Last Post: jl_678
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 127,368 10-04-2019, 08:57 PM
Last Post: tuxd3v
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 1,890 02-26-2019, 05:14 PM
Last Post: caillou
  How to install Mali drivers? tenspd137 0 1,738 02-11-2019, 09:57 PM
Last Post: tenspd137
