OpenWRT on the Rock64
i've finally got around to doing a new build of openwrt for the rock64 (sdcard) (it's headless no hdmi)
Using latest glibc / linux kernel 5.15.77 / switched to firewall4  / added bridger / watchcat / basic samba4 network sharing
https://disk.yandex.com/d/K4d4knF7iBqkHw                  ext4    (just use this one if you don't know)
https://disk.yandex.com/d/IG8mO4kMOPetwQ               squashfs
https://disk.yandex.com/d/Bh6bzY-V76XqPQ                   rootfs
NOTES :
* for some reason mount points don't seem super solid so you'll have to edit fstab manually perhaps or add a mount command in the startup or /etc/rc.local
* using samba4 because ksmbd runs out of memory on large files, but samba4 also runs out of memory unless you tick "force syncronous i/o"
* I decided to try dropping dropbear in favor of sshd, this might mean you have to set a root password  via the web interface before you can ssh in (it might not)
* included patches to enable usb3.0 phy/dmc/rng drivers from here
* USB3 port might actually be stable, this image tries enabling a couple of dwc3 quirks normally on other socs
EDIT:
Just did one last update to incorporate https://github.com/openwrt/openwrt/pull/11163 (but for all targets). the ax88179, seems to benefit from using the performance governor or increasing the minimum scaling frequency.
eg. "echo performance > /sys/bus/cpu/devices/cpu0/cpufreq/scaling_governor"
You can have this setting go through on bootup by putting the line in the "system -> startup -> local startup" section.
If you use software flow offload for the firewall you can also add "nft add flowtable inet fw4 ft { counter }" to make traffic counting work.
That's the last one from me for a while.
OpenWRT on the Rock64 - by CanadianBacon - 03-12-2022, 07:11 PM
RE: OpenWRT on the Rock64 - by helpmerock - 03-14-2022, 08:18 AM
RE: OpenWRT on the Rock64 - by CanadianBacon - 03-14-2022, 01:44 PM
RE: OpenWRT on the Rock64 - by CT456 - 03-31-2022, 01:29 PM
RE: OpenWRT on the Rock64 - by anchor00 - 06-10-2022, 05:43 PM
RE: OpenWRT on the Rock64 - by helpmerock - 03-15-2022, 09:41 AM
RE: OpenWRT on the Rock64 - by CanadianBacon - 03-15-2022, 02:33 PM
RE: OpenWRT on the Rock64 - by pescew - 09-15-2022, 05:25 PM
RE: OpenWRT on the Rock64 - by wilsonYan - 10-23-2022, 04:57 AM
RE: OpenWRT on the Rock64 - by wilsonYan - 11-05-2022, 03:07 PM
RE: OpenWRT on the Rock64 - by arunkhan - 04-16-2023, 12:34 AM
RE: OpenWRT on the Rock64 - by CanadianBacon - 04-22-2023, 09:12 PM
RE: OpenWRT on the Rock64 - by arunkhan - 04-24-2023, 12:40 PM
RE: OpenWRT on the Rock64 - by zet_lab - 04-02-2024, 11:17 AM
RE: OpenWRT on the Rock64 - by helpmerock - 04-03-2024, 08:48 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 412 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  Rock64 bricked shawwwn 7 5,853 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,380 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 390 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 2,005 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,616 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,199 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 786 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 988 10-07-2022, 07:50 PM
Last Post: rookie_267
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,089 09-18-2022, 02:29 PM
Last Post: mexicanflyer
