Android (android_dd_20160112) first impressions
(01-22-2016, 09:50 PM)janjwerner Wrote: Hey Folks,
I received the development board, so I can share some experience thus far, if you have any questions, want me to run some tests let me know.
First of all the board is pretty big - if you are used to raspberry pi, think twice the size (check the photo for the size comparison). Personally I don't mind, but you may say whoa this is big Wink
https://www.anony.ws/image/Jt6t
For the numbers fans: Antutu: final score: 23467
If you compare that to Amlogic or Rockchip
http://www.cnx-software.com/2015/11/19/a...omparison/
it seems to lag behind, on the other hand, Pine has no heatsink and I noticed very significant throttling when temperatures reached 120F.
If you want better performance heatsink is a must.
CPU-Z report available at valid.x86.fr/a/khq0ec
The standard range of apps work just fine, I had few crashes with app store installing antutu 3d, I guess there are some quirks of android that need to be worked out.
Netflix running at 1080p gets the temperature of the core (measured with the outside thermometer) to 110F.
KillAWatt EZ (the wall power meter) shows 4.8-5.2W while running Netflix.
Audio goes through HDMI unless you plug headphones.
Board shows great potential for whatever you will want to use it, game console / tv box, ARMv8 development machine. It needs some loving, but hey for 19/29$ you can't go wrong.
If the Antutu score is around 23-24000 then the Pine should perform somewhere close to the LG G3. Not bad at all I'd say!
Do you have the version with 2GB or the one with 1GB?
Cheers!
RE: Android (android_dd_20160112) first impressions - by g_t_j - 03-09-2016, 03:59 PM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 392,942 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,080 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,046 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,056 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,148 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,681 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,379 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 261,936 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,588 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 106,422 02-10-2019, 07:44 PM
Last Post: mmmarcus
