No HDMI output (don't think the boards are dead)
(07-12-2016, 06:42 AM)sanverm Wrote:
(07-12-2016, 06:36 AM)Ghost Wrote:
(07-12-2016, 05:56 AM)sanverm Wrote: I have one of the best HDMI cables available, it works with all other screen I have, but I will try a different one.
Additionally, I have this red led on the board that does not go out. Why is it on? what could be the error here? I have placed the wifi module correctly, put in the microsd and plugged mouse and keyboard in the usb and connected the power with the accompanying PINE power plug. This is how it should work right?
The red led is the power led. It just means that the board is on.
The development version of the board had a green led, but this got switched to a red in the production version.
Ah, thanks! This is helpful.  Smile
Have you tried an image other than the android image that was shipped? Suggest giving a linux image a try (debian mate from here is a good one: https://www.pine64.pro/downloads/ ). You can then confirm that you can ssh into the board, verify the board is alive and well, and if still having display issues, you have narrowed down the possible reasons significantly.
RE: No HDMI output (don't think the boards are dead) - by DonFL - 07-12-2016, 07:19 AM
  Star64: 4GB on 8GB boards Der Geist der Maschine 4 2,147 07-27-2023, 12:32 AM
Last Post: balbes150
  Pine HDMI -> DVI monitor Pineapple 4 7,918 09-10-2019, 11:28 AM
Last Post: Pineapple
  Need help in selecting boards ripcord 1 3,429 03-06-2019, 01:37 PM
  First Boot HDMI/USB problem reefer 1 5,061 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,284 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Linking the boards to make a server? Ramlatus 3 6,905 01-27-2018, 01:02 PM
Last Post: 11b2p508
  HDMI "Format not supported" sam452 3 6,650 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 16,152 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI and LCD hienhuynh1982 19 25,509 03-23-2017, 10:16 PM
  HDMI-VGA adapter. Blank screen. trumad 10 18,088 03-05-2017, 03:17 AM
Last Post: pfeerick
