No HDMI output (don't think the boards are dead)
First of all, hello. My Pine64's (x3; 2GB wifi?BT models) arrived yesterday! and I can't seem to get HDMI output (initially I thought the devices were not booting so the info below reflects my booting attempts)
I have tested x2 Pine64's to no avail
          a) Pine 64 2GB, wifi/BT module not installed
          b) No other peripherals connected (ie. keyboard or wired network)
          c) Used generic (fully tested) 8GB microSD cards, as well as 16GB ADATA microSD cards
          d) Used supplied power supplies, as well as 2.1amp USB outlet based adapters (Targus & Philips; reputable quality that work perfectly with higher amperage requiring devices such as tablets and other SoC's).
          e) Tested on LG 49UB8200 and LG 65UB9300 (both are 4K units); Also tried Onkyo TX-NR636 to pass HDMI through to 65UB9300.
          f) Also tested on HDMI capture card (1080p resolution limit).
          g) Used PhoenixCard 3.1.0 for phoenix based images, and Rufus and imageUSB for DD images (images from http://wiki.pine64.org/index.php/Pine_A6...re_Release and use of PhoenixCard and Rufus based upon http://forum.pine64.org/showthread.php?tid=1146)
          h) each time allowed 5-10 minutes to elapse once plugged in - only red LED was on with no other feedback from Pine64 nor televisions/receiver
          i) good quality HDMI cables with no previous issues with 3D use.
          j) I handled the Pine64's appropriately
          k) files were MD5 checked
          l) used 2 different Win7Pro units for writing of images to microSD cards
          m) Tested the following images: android-rooted-ver5.1.1-20160505-pine64-8GB, remix-v2.0-20160415-pine64-16GB, Pinea64_android_lollipop_db1000_20160216, debian-mate-jessie-20160501-lenny.raposo-longsleep-pine64-8GB, remix-v2.0-20160415-pine64-8GB, pine64-image-debianmate-310101bsp
This is not my first endeavor, as I have multiple Raspberry Pi units as well other computers, servers, and an advanced network in use.
After all these attempts the devices have failed to output HDMI.
I cannot think of any further testing that I can perform. The only other monitors that I have access to do not have HDMI inputs and unfortunately HDMI to DVI adapters are known not to work with the Pine64.
additional
Reading some of the threads, one person commented that there are a lot of HDMI issues.
I booted up the OpenHAB microSD (well couldn't really tell if it booted up or not as I had no HDMI output, but as in every case the red LED remained lit) and plugged in the ethernet cable about 5 minutes later and there was network activity (good sign).
I then loaded an android microSD card, and I checked my DHCP server on my router and there was an IP assignment to a new android device!!!!!!!!!!!
So how does one fix this HDMI problem (thinking that this is my most likely problem)?
Thank you.
No HDMI output (don't think the boards are dead) - by thegooddoctor - 07-01-2016, 04:03 PM
  Star64: 4GB on 8GB boards Der Geist der Maschine 4 2,087 07-27-2023, 12:32 AM
Last Post: balbes150
  Pine HDMI -> DVI monitor Pineapple 4 7,882 09-10-2019, 11:28 AM
Last Post: Pineapple
  Need help in selecting boards ripcord 1 3,410 03-06-2019, 01:37 PM
  First Boot HDMI/USB problem reefer 1 5,042 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,240 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Linking the boards to make a server? Ramlatus 3 6,879 01-27-2018, 01:02 PM
Last Post: 11b2p508
  HDMI "Format not supported" sam452 3 6,621 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 16,062 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI and LCD hienhuynh1982 19 25,336 03-23-2017, 10:16 PM
  HDMI-VGA adapter. Blank screen. trumad 10 18,031 03-05-2017, 03:17 AM
Last Post: pfeerick
