Settings are reset after reboot
(08-29-2023, 08:45 AM)fxc Wrote:
(08-28-2023, 06:26 PM)car46999 Wrote:
(08-15-2023, 02:33 PM)fxc Wrote: For reference, https://wiki.mobian-project.org/doku.php...-variant-2 is the correct method to edit the scaling persistently. I have removed two comments above referencing the wrong path, potentially misleading users (and this already caused damage in the community chat).
I tried this last night on 20230710-0752-postmarketOS-v23.06-phosh-22.2-pine64-pinephone, but the directory etc/phosh does not exist on my phone. I created the directory, copied the file over and made the edit. But the phone would then boot to a console login.
Same thing happened if I edit /usr/share/phosh/.
That would happen if there is a syntax error in the file. Best to provide the whole file here and then we can tell you what went wrong.
For postmarketOS, the instructions are equal: https://wiki.postmarketos.org/wiki/Phosh#Screen_Scaling
Good call. In the original /usr/share/phosh/phoc.ini file, the [output:DSI-1] has a # in front of it. I deleted it and that worked. Thanks.
#[output:DSI-1]
# scale = 2
scale = 1.5
Bonus question, is there anyway to keep that scale but have the full size keyboard?
Settings are reset after reboot - by lacriz - 02-17-2022, 08:31 AM
RE: Settings are reset after reboot - by svenh - 01-30-2023, 10:18 AM
RE: Settings are reset after reboot - by fxc - 08-15-2023, 02:33 PM
RE: Settings are reset after reboot - by car46999 - 08-28-2023, 06:26 PM
RE: Settings are reset after reboot - by fxc - 08-29-2023, 08:45 AM
RE: Settings are reset after reboot - by car46999 - 08-29-2023, 05:28 PM
  The language I've added on settings doesn't appear Gon 2 1,789 08-15-2022, 01:55 PM
Last Post: Gon
  No automatic hub connection on reboot. --- 0 1,051 02-06-2022, 06:52 PM
Last Post: ---
  Poweroff/Reboot fails AndyM 2 3,020 09-18-2021, 06:55 PM
Last Post: jmorris
  Backup user data and settings kratz00 4 5,254 02-28-2021, 03:39 PM
Last Post: kuleszdl
