Freecad on the PBP
Flatpak-type images usually suck anyway, especially if like me you have a dark theme set in your window manager. Which they just ignore and give you instead this glaring default bright white/light GTK (or whatever) theme, which I find absolutely jarring, especially at night.
Anyway, Python dependencies conflicting with system Python is certainly nothing new. Solutions like pyenv are designed specifically for this case.
Alternatively you should be using your distro's package, as cohesive dependency management is sort of the whole point of package managers after all. If there is some conflict, maybe raise an issue either with your distro or maybe FreeCAD, depending.
Cheers,
TRS-80
Protocols, not Platforms
Freecad on the PBP - by flatulent_piney - 02-15-2022, 07:02 AM
RE: Freecad on the PBP - by tophneal - 02-15-2022, 02:37 PM
RE: Freecad on the PBP - by TRS-80 - 02-17-2022, 11:06 PM
