Setup/settings lost on reset/reboot
Hi guys,
So ive managed to get the pinephone making and receiving call in the UK, where i'm based. The problem is that every time the phone restarts or is switched off, it forgets ALL the settings needed for cellular calls, and even the wallpaper settings! (This is when an update requires reboot/power lost due to battery drain etc)
I therefore need to do the following every time:
Set UK EE  cellular data APN for VoLTE
add Minicom (via pkcon install) and setup:
    AT+qdai=1,0,0,1,0,1,1,1
    AT+qmbncfg="select","VoLTE-ATT"
    AT+qcfg="ims",1
    AT+cfun=1,1 (to reboot modem)
set ALSAMixer Playback and Capture settings to appropriate levels (They are always maxed out to 100% and cause feedback/noise)
Test with:
    AT+qtts=2,"welcome to test" to make sure audio is ok
Then it works like a charm...
So, my question is... Is this anyone else's mileage and if so, can i script this setup? (I read minicom is hard to script) Or is there a way to bake the settings into the modem/software?
OR
Do I have a faulty pinephone?
Thanks for any thoughts - loving this little toy!!
Setup/settings lost on reset/reboot - by GrapeJuice - 02-10-2022, 05:40 AM
  New phone, KDE desktop settings reset on reboot zzb0 2 1,826 10-15-2023, 10:19 PM
  Manjaro: Settings doesnt open nbh 0 620 09-24-2023, 05:25 PM
Last Post: nbh
  Hard reset Nootaku 1 1,582 01-21-2023, 06:56 PM
  nextcloud setup mruser1 2 1,766 12-05-2022, 03:22 AM
Last Post: alaraajavamma
  Lockscreen clock AM/PM when settings are 24 hours Kimberley van Buyten 1 1,089 06-16-2022, 10:54 PM
Last Post: shulamy
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,752 05-03-2022, 12:42 PM
Last Post: altulke
  Lost Display Teop 0 1,004 11-11-2021, 10:44 AM
Last Post: Teop
  4G disconnect requires reboot cnxsoft 9 6,623 10-10-2021, 04:19 PM
Last Post: prenex
  [phosh][beta11] audio settings lost after making outgoing call dcinoz 1 1,971 06-22-2021, 03:57 AM
Last Post: dcinoz
  Fixed - Do not use Plasma Mobile Settings -> Screen application for now acrux 2 3,123 05-12-2021, 06:09 AM
Last Post: acrux
