DisplayPort Out question
#46
(09-02-2022, 02:49 PM)uzanto Wrote: Mine works on the nexdock 360 but you need to charge the phone from the nexdock then go to display settings, press on the nexdock monitor and then on refresh rate set it to 30 hz and apply settings, it will revert back to 60 and you will have video out and keyboard and touchpad.
If charging is not enabled keyboard and touchpad wont work
Got mine working with a satechi 7 ports USB-C hub on arch linux (danctnix) with phosh. Monitor, keyboard and mouse are all working (typing this from this combo now Smile ). Only thing that needs to be done is set the resolution to 1920x1080 to avoid seeing garbage on the right side of the screen.
The 4K monitor is connected through a KVM switch and I will lose the connection now and then when switching between my different PCs (work/private/pinephonepro).
If I lose the connection and manage to get re-connect I also lose all the settings I applied.
Anybody has a clue on how  to preserve the settings?
RE: DisplayPort Out question - by Arwen - 02-02-2022, 03:01 PM
RE: DisplayPort Out question - by Arwen - 02-02-2022, 03:24 PM
RE: DisplayPort Out question - by frankt - 02-02-2022, 03:31 PM
RE: DisplayPort Out question - by frankt - 02-05-2022, 07:35 PM
RE: DisplayPort Out question - by talpa - 02-17-2022, 03:02 PM
RE: DisplayPort Out question - by thehiggsfermion - 02-05-2022, 09:27 PM
RE: DisplayPort Out question - by bcnaz - 02-06-2022, 12:26 AM
RE: DisplayPort Out question - by uzanto - 02-06-2022, 06:05 AM
RE: DisplayPort Out question - by frankt - 02-09-2022, 03:52 PM
RE: DisplayPort Out question - by sringgen - 02-09-2022, 04:14 PM
RE: DisplayPort Out question - by frankt - 02-09-2022, 06:11 PM
RE: DisplayPort Out question - by frankt - 02-10-2022, 02:26 PM
RE: DisplayPort Out question - by dexy - 02-11-2022, 02:54 PM
RE: DisplayPort Out question - by frankt - 02-11-2022, 08:40 PM
RE: DisplayPort Out question - by Arwen - 02-12-2022, 11:35 AM
RE: DisplayPort Out question - by frankt - 02-12-2022, 04:59 PM
RE: DisplayPort Out question - by frankt - 02-13-2022, 09:20 AM
RE: DisplayPort Out question - by frankt - 02-13-2022, 11:12 AM
RE: DisplayPort Out question - by frankt - 02-13-2022, 05:41 PM
RE: DisplayPort Out question - by Arwen - 02-14-2022, 11:11 AM
RE: DisplayPort Out question - by sringgen - 02-16-2022, 05:12 PM
RE: DisplayPort Out question - by frankt - 02-16-2022, 08:05 PM
RE: DisplayPort Out question - by sringgen - 02-17-2022, 07:50 AM
RE: DisplayPort Out question - by Arwen - 02-17-2022, 09:19 AM
RE: DisplayPort Out question - by sringgen - 02-17-2022, 09:58 AM
RE: DisplayPort Out question - by kaida - 02-22-2022, 09:12 AM
RE: DisplayPort Out question - by magdesign - 03-03-2022, 05:28 AM
RE: DisplayPort Out question - by frankt - 03-03-2022, 05:33 PM
RE: DisplayPort Out question - by frankt - 03-03-2022, 08:11 PM
RE: DisplayPort Out question - by frankt - 04-06-2022, 03:29 PM
RE: DisplayPort Out question - by carlp - 05-15-2022, 12:51 PM
RE: DisplayPort Out question - by Deus - 08-30-2022, 08:38 PM
RE: DisplayPort Out question - by frankt - 09-01-2022, 08:32 AM
RE: DisplayPort Out question - by uzanto - 09-02-2022, 02:49 PM
RE: DisplayPort Out question - by rosco_pc - 09-22-2022, 09:50 AM
RE: DisplayPort Out question - by frankt - 12-03-2022, 10:57 AM
RE: DisplayPort Out question - by carlp - 02-15-2023, 03:31 AM
RE: DisplayPort Out question - by etbe - 06-11-2023, 02:20 AM
  Battery Life is it possible?? Tech Question (sort of) scrwbigtek 4 3,388 05-11-2022, 06:01 AM
Last Post: danimations
Question Possibly dumb question For_lack_of_a_better_name 1 1,473 03-06-2022, 04:54 AM
Last Post: fxc
